LS3 C5 conversion thread
Old Dec 23, 2009 | 05:34 PM
Thickraybans's Avatar
Thickraybans
Originally Posted by lucky131969
Outstanding! I'm sure many(myself included) will appreciate you taking the time to explain the details.
Old Dec 23, 2009 | 05:53 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
my number 7 piston went the exact same way. even broke at the same location. I did the LS3 (416) conversion as well...stupid stock cast pistons
Old Dec 24, 2009 | 08:07 AM
VonDutch's Avatar
VonDutch
You did a great job !
Thanks for posting
Care to post build cost start to finish ?
Thanks, & Happy New Year to all
Von
Old Dec 24, 2009 | 08:56 AM
AU N EGL's Avatar
AU N EGL
Putting a dry sump in too?
LS3 Oiling issues - Click here
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Originally Posted by aweil
The problem that I see with installing heads and intake first is that the chains which support the engine while you install it would have to go in the front and rear of the cylinder heads. I'm not sure that there is room between the head and firewall to get the bolts which would hold the chains to the head out after the motor is installed. For sure, I didn't want to find out! lol
I want to say that if you left the intake off you could fabricate a lift plate similar to this to remove the engine:
Good point, it is a bit tight back there. Thanks a lot for answering all the questions. Very helpful - Merry Christmas everyone.
Old Dec 24, 2009 | 05:46 PM
magnetized's Avatar
magnetized
St. Jude Donor '09
Very
Old Dec 25, 2009 | 08:59 AM
aweil's Avatar
aweil
I don't road race, so that isn't a consideration. Thanks for the info though, if I decide to down the road, I'll throw one in!
Old Dec 25, 2009 | 09:07 AM
aweil's Avatar
aweil
Thanks for posting
Von
Let's see....
Core engine: $800. I did a preliminary cleaning and teardown removing cam, pistons, crank, etc. and brought the block and crank to my machine shop. I was hoping to reuse the stock rods and pistons, but my particular core was victim of a dropped valve and it created a bit of carnage.... 3 pistons were beat and one of the cylinders had a scratch in it that required a .005" hone. Also, to stay with a shelf flattop 4.070" piston with valve reliefs, I needed
a 6.125" rod as opposed to a factory 6.098" rod to keep the quench correct. Having to hone the block contributed significant additional cost, but now I have forged rods and pistons.
Pistons: $670ish if I remember right. Mahle power pak with pistons, pins, rings, and retaining clips.
Rods: $550ish for Eagle rods, ended up with another $150 in machine work for them to get the big end clearances right. Maybe I should have bought the compstar rods instead?
Bearings: $200 I think for main and rod bearings, Clevite 77 stuff, not H series.
Machine work: $1100 ballpark. 8 cylinders honed .005" over, block cleaned and deburred, edges knocked down, DOD holes tapped and plugged, mains align honed, new cam bearings, rotating assembly balanced.
Timing cover: $165 through Jegs
Headgaskets: $80
CNC Cylinder heads, intake rockers and rocker stands: $1475 from TSP.
Mill heads some more: $100 (.020" milling was ~ 2.5 cc from 70cc unmilled, .040" was ~5 cc total, we stopped at 65cc).
LS3 Intake manifold, injectors, fuel rails: $400 on ebay.
Wiring harness adapters: $150
Hex A Just LS2 2x cam gear: $150
LS3 valley cover: $30 on ebay
Theres some other stuff that I don't know off the top of my head... front and rear main seals, 24x crank sensor, valley cover gasket.
I saved a BUNCH of money doing the removal, assembly, and install myself.
Old Dec 25, 2009 | 09:23 PM
FSTFRC's Avatar
FSTFRC
Let's see....
Headgaskets: $80
Great post Andrew! Thanks for sharing the information for putting in a LS3 in your Z06.
FSTFRC
Old Feb 21, 2010 | 08:07 PM
sami85L98's Avatar
sami85L98
Just came accross this thread when doje reroute me, man amazing job thanks for sharing.
Old Feb 21, 2010 | 08:28 PM
Rob's 73's Avatar
Rob's 73
I just installed my LS3 418 with the heads on. I left the cradle a little low (3/4") until I finished connecting all the wires and installing the intake. I found it much easier to do all the head work with the motor on the stand.
I like the intake valley lift plate!
Old Apr 18, 2010 | 02:34 PM
AVB's Avatar
AVB
I'm just about finished doing the same thing and am getting a Throttle Position Sensor Fault. Did you use an LS3 Throttle Body or LS2?
Old Apr 18, 2010 | 03:50 PM
  #33
WKMCD's Avatar
WKMCD
Nice work Andrew.
I've been running L92 heads for almost 4 years now. First on my 403 and now 427. I've used 4 different cams in that period. You were smart to avoid throwing a big donket dic cam in there and ruining the beaty of the L92/LS3 heads - great average power. I'm going to bet your tip in is very strong and the car is just a blast to drive. Too many people have tried HUGE cams with these heads only to make less HP and and be much less fun to drive. The sweet spot on the intake side seems to be in the 230 degree range for best average power.
How much timing were you able to crank in? The heads LOVE spark lead.
Well done,
Kevin
Old Apr 19, 2010 | 10:48 AM
  #34
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
was 447rwhp and 429rwtq the end results?
Old Apr 19, 2010 | 10:57 AM
  #35
aweil's Avatar
aweil
I used an LS2 throttle body, but I believe they are interchangeable. Assuming that you got the proper conversion harness from Casper's, it should work. HOWEVER, I have found that it is SUPER easy to bend the pins in that thing, you should check yours and make sure that every pin is making a good connection... you can check with a voltmeter on continuity on both sides of each connector without taking it apart.
Old Apr 19, 2010 | 10:59 AM
  #36
aweil's Avatar
aweil
Originally Posted by WKMCD
Nice work Andrew.
Well done,
Kevin
I want to say that I was able to get 28 degrees total timing in my tuneup... at that point there was no spark knock, however the power quit increasing as well so I figured I'd leave well enough alone.
Old Apr 19, 2010 | 11:00 AM
  #37
aweil's Avatar
aweil
They are the current results, but not the end.
I purchased an LG G6X3 cam that I'm going to try to see if I can get closer to 500 rwhp, plus the spinmonster cam isn't rowdy enough for me. I guess I'm not as old as I thought I was? lol
To LS3 C5 conversion thread
Old Apr 19, 2010 | 11:03 AM
  #38
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The G5X3 cam that I have in my C5 is a little more cam than I would like to run on the street myself. It reminds of the 60 era muscle cars.
Old Apr 19, 2010 | 02:54 PM
  #39
AVB's Avatar
AVB
I'll double check for bent pins but so far I'm finding the later, 09+, LS3 tb's (PN GM 12605109) may have issues. There isn't a harness adapter for these so I'll assume someone knows it's not just a wiring issue.
Old Apr 19, 2010 | 03:02 PM
  #40
aweil's Avatar
aweil
Interesting. My buddies with '08 LS3 cars have borrowed my (stock) LS2 throttle body to dyno against their ported stockers to see if there were any gains. There weren't.
I had to use this wiring harness to hook up my LS2 TB to my ECM:
http://www.casperselectronics.com/st...oducts_id=1087
Maybe the '09 TB is different?
I have gotten the code you mention once, it was because I forgot to plug the TB in. :embarrassed:
