jacking up a c5
Jan 24, 2010 | 04:55 PM
jacking up a c5
I want to jack my 02 just to remove one wheel at a time to clean and polish the inside of the rims. How do I safely lift and where would I place jackstands to do one wheel at a time?
Jan 24, 2010 | 05:25 PM
St. Jude Donor '09
The lift points are listed in the owner's manual. If you do not have one, the manual is available for download from several on-line outlets.
Jan 24, 2010 | 05:29 PM
Get yourself some jacking pucks if you don't already have them...
Look for a hole along the rocker panel, stick her in and twist...
Jan 24, 2010 | 05:50 PM
Quote:
Originally Posted by
UniqueDoug
I see how to do that, but where can I place a jackstand while the tire is off?
Jan 24, 2010 | 05:54 PM
guido7834
Right where the lower A meets the cross member to the other side's lower A, does this wording make sense??
Jan 24, 2010 | 05:55 PM
guido7834
Jack from the cross-member and place jackstand under the frame rail at the approved lifting points. Or jack at the frame rail and place the jackstand under the cross member, easy
Jan 24, 2010 | 06:08 PM
I think I got it, any pics would be helpful.
Jan 24, 2010 | 06:59 PM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Jan 24, 2010 | 07:55 PM
Here's a pic. make sure you use a jacking puck on the points under the rocker panels if you lift at each corner.
Jan 24, 2010 | 08:08 PM
DeeGee
Awesome schematic, exactly where my previous post stated...
Jan 24, 2010 | 08:09 PM
UniqueDoug
we pilots like pictures
