Help - Harmonic Balancer Bolt
Old Feb 5, 2010 | 10:23 PM
Yellow Z's Avatar
Yellow Z
Default Help - Harmonic Balancer Bolt
I am trying to remove the harmonic balancer bolt. I used a 1/2 inch impact gun to no avail. I even purchased a new 650 lb-ft impact gun and still did not remove it. I am thinking about using a propane torch to heat the pulley. This is on a C5 Z06. Any thoughts or suggestions?
Old Feb 5, 2010 | 10:41 PM
coanan's Avatar
coanan
good info here
http://forums.corvetteforum.com/c5-t...1st-day-2.html
Old Feb 6, 2010 | 12:39 AM
Yellow Z's Avatar
Yellow Z
Nice thread. I don't have enough space to use all the tools they did. Should the heat be applied to the bolt or the pulley?
Old Feb 6, 2010 | 12:54 AM
ILM-Express's Avatar
ILM-Express
MFIC
I made this tool to hold mine to get it off, it was tight
Old Feb 6, 2010 | 09:16 AM
Blow Torch's Avatar
Blow Torch
DANG....That is some great ingenuity
How much would you charge me to use that puppy if I have to pull one off again??? That's MUCH better than trying to hold the flywheel
Old Feb 6, 2010 | 09:25 AM
USAFZ06's Avatar
USAFZ06
never had a problem holding the flywheel and having the car in like 4th gear with the e brake on very tight with just a 1/2" rachet and a small breaker bar...all you sissies and your impacts...plus i dont like the thought of all the pounding on that bolt being that its in the cranks with all those nice bearings in the bottom end...its not even that difficult to break loose with the method i just said...man up guys!
Old Feb 6, 2010 | 09:33 AM
aquachuck1's Avatar
aquachuck1
Default hb
I think the bolt is 23mm...use 1/2 breaker bar and I put a 4 foot length of copper pipe I had laying around over the breaker bar....car in 4th gear (hand brake on) and slow steady pressure....Good Luck
Old Feb 6, 2010 | 09:54 AM
vettenuts's Avatar
vettenuts
I have done several this way as well.
Old Feb 6, 2010 | 01:08 PM
zeevette's Avatar
zeevette
That's a cool tool for A/Ts, but not really applicable in this case. I used a std. 1/2" ratchet with half a jack handle over the end. There's locktite on the bolt, so it breaks loose kind of softly. It does take some muscle, though. BTW. a 15/16" socket fits perfectly.
Old Feb 6, 2010 | 01:41 PM
ILM-Express
MFIC
Originally Posted by zeevette
That's a cool tool for A/Ts, but not really applicable in this case. .
This tool will work on either A4 or M6, and it does apply unless he has an aftermarket balancer.
Old Feb 6, 2010 | 02:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Apply some HEAT to the bolt head and heat the head to loosen the the RED LOCKTITE on the bolt threads. Once the locktite is warm/hot, loosening the bolt will be easier.
Once the bolt is out, heat the damper hub to about 150 deg before you crank it off with a puller and you will be amazed how much easier it is to remove.
BC
Old Feb 6, 2010 | 03:52 PM
Blow Torch's Avatar
Blow Torch
Yea; can't imagine why it wouldn't work on a M6
And I guess I was being selfish, because I was referring to using it on MY next job
Old Feb 6, 2010 | 11:44 PM
Yellow Z's Avatar
Yellow Z
Thanks everyone. Screw the impact wrench. No substitute for a four foot cheater pipe and breaker bar. Didn't think I would have enough space but it worked fine.
To Help - Harmonic Balancer Bolt
