Throttle body hook up
Old Feb 7, 2010 | 08:42 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Default Throttle body hook up
Here is why I don't like to do my own work. I took the throttle body off my car to paint it. Easy, 3 bolts, a couple of electrical connects and a hose. I clean it all up, tape it all up and painted it. As I'm painting it I'm asking myself, what hoses get connected to the 2 lower pipes that are on the lower portion of the throttle body? I don't remember disconnecting any other hose but the one on top. I looked at the car and don't see any hoses that would have come from these pipes.
What gets hooked up here if anything?
Thanks from the absent minded weekend warrior!
Old Feb 7, 2010 | 09:27 AM
c5blkvetteguy's Avatar
c5blkvetteguy
Coolant lines. You might have the coolant by-pass (done before you got the car) so thats why you dont remember taking them off.
Old Feb 7, 2010 | 09:49 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Okay if that is the case, I just leave those lines open as they were?
Old Feb 7, 2010 | 09:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES! There used to flow coolant thru the throttle body to prevent TB Icing. Its not really needed. Hell, I live in CT and drive my car in all sorts of cold weather and have never had an icing issue.
The C6 TB doesn't even have a coolant passage. Guess GM wised up.
You can put a rubber cap on them if it makes you feel any better but, it just a coolant passage that isn't needed.
BC
Old Feb 7, 2010 | 11:56 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Thanks Bill. I will leave them open as I have not had any issues with them while open.
To Throttle body hook up
