heads cam and?????
Old Feb 9, 2010 | 09:56 PM
kjmj's Avatar
kjmj
Default heads cam and?????
I will be doing a head and cam pkg in about a month through a reputable shop. 243 heads, 224/228 112 lsa, with 600/612 lift. My question is what else do I need to have replaced? I have been told the timing chain and an ls6 oil pump. Is there anything else while they have it apart? Thanks for your help.
kj
Old Feb 9, 2010 | 10:06 PM
corvette8189's Avatar
corvette8189
springs
pushrods
timing chain
crank bolt
gaskets
new head bolts
probally some other stuff but cant think of it off the top of my head
Old Feb 10, 2010 | 07:57 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by corvette8189
springs
pushrods
timing chain
crank bolt
gaskets
new head bolts
also a good idea at the same time
Under drive pulley
High volume PP oil pump
Edit:
What cam is this ? 224/228 112 lsa, with 600/612 lift.
most 224/228 are 581/588 lift
With cam lift UNDER .600 keeps reliability
Besides the LS6 intake and 243 heads do not flow any more above a 600 life cam vs 590 lift, so why even go there ?
The springs for cam lifts above 600 are different then springs for cam lift UP TO 600.
To heads cam and?????
