Are all headers essentially the same?
Old Mar 16, 2010 | 08:18 PM
Nick1's Avatar
Nick1
Default Are all headers essentially the same?
A friend just got a new aftermarket system, and it looks pretty good, stainless/long tubes with high flow cats. Someone was saying at a local speed shop that the performance results could vary greatly, as much as 30hp?? That seems like quite an exaggeration to me. What do you think? What kind of hp. increase can reasonably be expected from such a conversion or between various types of headers? Thanks!
Old Mar 16, 2010 | 08:42 PM
postwhore's Avatar
postwhore
no , there are numerous variations such as tube length , tube diameter , type of collectors , bends and so on
Old Mar 16, 2010 | 08:49 PM
c5blkvetteguy's Avatar
c5blkvetteguy
A tune will also help the hp numbers.
Old Mar 16, 2010 | 09:13 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
It's one of those impossible questions. Not only will different designs produce different numbers but while header A may outperform header B on engine X, header B may very well outperform header A on engine Y.
Old Mar 16, 2010 | 09:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are differences between headers. Some fit a LOT better than other systems and some perform better than others. If one system had longer primary tubes and advanced collectors, it going to perform to a higher HP level than a copy cat generic system.
On another note, IF you installed the LOW COST HEADER on a STOCK engine and did a back to back comparison between a high DOLLAR Brand name header system, you would most likely see minimal HP/TQ differences.
Dollar/performance gains are important and not everyone has the money OR wants to spend $2500 for a system that gives them 40 HP on a stock engine where as $900 dollar system will provide 35 HP. on the same engine.
When you go full out and have MASSIVE heads.cam and power adders, there are times when specialty (high dollar PREMIUM designed) headers stand out.
Will you have the exact same HP/TQ from a $900 vs $2000 system. Most likely NOT but, is the difference between the two worth $1100?
BC
Old Mar 16, 2010 | 09:55 PM
Mark C5's Avatar
Mark C5
And while we're on the matter of price, I used to believe you get what you pay for until I saw this:
This is on a top of the line header from a well known manufacturer. They claim this does not affect performance and while I have no reason to believe otherwise, would you really want this on your car? Would you feel good paying $1500.00 + for this kind of quality?
Seems you really need to do your research these days.
Old Mar 16, 2010 | 10:59 PM
wilson34's Avatar
wilson34
wow.
Old Mar 16, 2010 | 11:10 PM
motogib1's Avatar
motogib1
A short answer is that there are variations in "long tube" headers. I saw an excellent dissertation on headers by Tony Mamo in the last couple of years. Try a search on him.
Old Mar 17, 2010 | 03:10 AM
Bluefire's Avatar
Bluefire
Let's not forget metal thickness. I have heard some off-shore mfgs. use lighter materials.
thickness = longevity
Old Mar 17, 2010 | 08:25 AM
AU N EGL's Avatar
AU N EGL
BC
with Bill
Personally dont buy cheap headers. You may not be happy in two years.
Old Mar 17, 2010 | 09:15 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Default The basic run down..
Material used: Stainless is better than mild steel. Some coat both mild or stainless, there are arguments on whether mild or stainless is better. (heat)
Primary size: Some (Hedman) have 1 5/8 primaries for lots of low end torque... most start with 1 3/4 for and some step that size up to 1 7/8.... and even still, some start with 1 7/8 all the way, and some step from 1 3/4 to 1 7/8.
Collectors size: Some (I know if a popular off shore brand) that is 2.5 and some places offer 3.0.
Collector Design: Some have all primary pipes dump into a smallish merge area with crummy welds, some have a longer collector with better welds, some have stamped "waisted collectors - like the hips of a curvey woman- to help with mid range torque... and even more... some have a "spike" in the middle of the primary pipes that point rearwards that help further with scavenging...
Then there are the subtle differences like even thought two companies have stainless, what "grade" of stainless?
Fitment of not just in the engine bay but also for o2's...
Warranty, cost, customer service, mild differences in power, what county built? (US/china) etc.
Old Mar 17, 2010 | 11:25 AM
postwhore's Avatar
postwhore
I didn't even try to list all the variables.
there are too many
Old Mar 17, 2010 | 12:03 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
unbelieveable
Old Mar 17, 2010 | 01:42 PM
RDKING's Avatar
RDKING
Originally Posted by AU N EGL
with Bill
Old Mar 17, 2010 | 03:51 PM
AU N EGL's Avatar
AU N EGL
i dont have a problem with this pic.
What does the INSIDE look like? is it nice a smooth for the exhaust gasses to flow smoothly. or are there bumps inside the exhausts to cause turbulence ?
besides, that part of the header is almost hidden under the car.
Question is,
are you buying for looks or performance ?
Old Mar 17, 2010 | 04:23 PM
Mark C5's Avatar
Mark C5
Question is,
The inside looks just as bad as the outside. It's a slip fit joint. The weld is also very poor quality and I question how it will hold up after many heat cycles.
This joint is not under the car but instead up near the flange, easily seen from the top of the engine.
But if you think this is worth $1500.00+ more power to ya guy
Old Mar 19, 2010 | 04:32 PM
postwhore's Avatar
postwhore
looks like an old BlackJack $39.99 header
Old Mar 19, 2010 | 08:25 PM
Nick1's Avatar
Nick1
Hey Everyone! Thanks for all the comments!!
To Are all headers essentially the same?
