clutch fluid leaking..help
Old Apr 4, 2010 | 06:02 PM
michaelcerv's Avatar
michaelcerv
Default clutch fluid leaking..help
I have 2000 c5 turbo car. The clutch and cylinders are new. A fluid leak developed after the pedal assembly. It looks like a braided line going from the pedal assembly into the trans. There is no room to see much. I would like to see a manual or a diagram of the system to understand it. Any one have any info on this? really appreciate it.
Old Apr 4, 2010 | 07:19 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
You might luck out and find that the line coupling is not fully connected.
Old Apr 4, 2010 | 08:26 PM
michaelcerv
thanks for this. I think the line ruptured. only leaks when the car is running. It looks like it is coming out of the line.
thanks again
Old Apr 4, 2010 | 09:05 PM
Eric D's Avatar
Eric D
thanks again
Car running or not should really make any difference. Did you have the clutch installed? If yes, have you taken it back to the installer?
Old Apr 4, 2010 | 09:51 PM
michaelcerv
I agree it should not make any difference. We pressed the pedal numerous times and had very little leaking. When the car was running the leaking was significant. I had my hands all over the line. I had the clutch replaced along with the slave, master cylinder and had a remote bleeder installed. They did not touch this line. I have two options. If i bring it to them they will take at least a week to fix it and it will not be under warranty. Or I may bring it to my regular guy who did not do the clutch. Your diagram was great. thanks again
Old Apr 4, 2010 | 10:00 PM
XXXC5's Avatar
XXXC5
we just replaced my slave and master cylinder and added a remote bleeder, took it for a test drive at came back it was leaking. we took a peek up in there and found out the remote bleeder was leaking. we took it off and put the stock bleeder on and so far 500 miles later its fine.
Old Apr 4, 2010 | 10:23 PM
KCvetteowner's Avatar
KCvetteowner
So the leak is below the junction in the line (i.e. you have to replace the line coming FROM the slave?
Is the line protected from heat?? I would consider a heat shield on the line when you have it replaced, just a little added protection.
Old Apr 4, 2010 | 10:43 PM
michaelcerv
It does not look like its coming from the remote bleeder but from a ruptured line which I hope to get at tomorrow. In terms of a heat shield I agree. Is there one you have used? recommend?
thanks guys
Old Apr 4, 2010 | 10:48 PM
KCvetteowner
thanks guys
Look at DEI Cool Tubes available at most performance parts shops...
Old Apr 4, 2010 | 11:08 PM
Carcass's Avatar
Carcass
I'm not sure what you mean by "they did not touch this line"?
If the slave and master were both replaced,so were the lines,and then connected at the quik connect.
If a line is leaking that they didn't touch,then it's not the clutch line that's leaking.
Are you sure it's not a brake line leaking?-that would explain the higher pressure/bigger leak with the car running...
Old Apr 5, 2010 | 12:22 AM
81c3's Avatar
81c3
Its absolutely impossible not to touch the line when the clutch and cylinders are replaced.
Old Apr 5, 2010 | 07:43 PM
michaelcerv
I know what I was looking at but not sure exactly which line it is. Will have the car on a lift tomorrow and see more. I will let you guys know what I find. Thanks for the input.
To clutch fluid leaking..help
