Mysterious coolant leak..
Old Apr 14, 2010 | 06:14 PM
servohead's Avatar
servohead
Default Mysterious coolant leak..
Hi,
Just today did an oil change on my '99 hardtop and I was bummed to see a coolant leak - one drop from the front spring. Looking up I saw traces following the drivers side of the timing chain cover and then
couldn't see where from there. From the top it was really wet on the passenger side of the timing
cover. SO I thought it was the water pump but after 15 minutes of searching with mirrors the water pump really looks dry....(?!!?).
It's not a bad leak yet, I really only saw one drop of dexcool and the resevoir is still just about full.
What are some common coolant leaks in the water pump area? Has anyone had anything similar? Im at 75k miles right now and the engine is all original - no mods.
Old Apr 14, 2010 | 06:30 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Most likely the water pump shaft seal. You may not see it there as it can be thrown when the engine is warm and running. Normally the leak only happens when the cooling system is up to full pressure, 15 psi.
Changing the water pump is one of the more easy things to replace on the Corvette.
Old Apr 14, 2010 | 06:53 PM
Roger Z06's Avatar
Roger Z06
Check the coolant line cross overs from head to head, they can leak easily when the car is running and look dry when it is off.
Old Apr 14, 2010 | 06:57 PM
Z06supercharged's Avatar
Z06supercharged
I betting its the pass side water pump gasket leaking and not the pump itself or anything else. Could barely see my leak from underneath. $5 gaskets and it as fixed. Left the pump alone even though it had 45K on it.
Old Apr 14, 2010 | 08:08 PM
servohead's Avatar
servohead
Nice! Well what I did for today was just clean it up and I'll check it
out in a few days and see where the fresh leak is coming from. Great ideas guys - thanks for the help! Now hopefully I can fix it!
Old Apr 17, 2010 | 04:54 PM
BLUE Y2K's Avatar
BLUE Y2K
Does your belt squeal when you start your car? If so, I would check the small hose from the top right side of the radiator to the intake right above the water pump pulley.
To Mysterious coolant leak..
