Thermostat
Old May 3, 2010 | 11:47 AM
zee OH sex's Avatar
zee OH sex
Default Thermostat
I have an 01 Z06, im looking to put in a 180 or 160 t-stat. What do you guys recommend and where would you get it from? Summitracing seems to have no selection.
Thanks!
Old May 3, 2010 | 12:20 PM
76 VETTE's Avatar
76 VETTE
Thanks!
Old May 3, 2010 | 12:24 PM
vettenuts's Avatar
vettenuts
Not sure what you are doing, but the stock unit can be easily modified to open at different (lower) temperatures for less then $1.
Old May 3, 2010 | 12:26 PM
postwhore's Avatar
postwhore
I'd recommend leaving it alone and get a good radiator.
the stock one is a joke
Old May 3, 2010 | 12:35 PM
zee OH sex's Avatar
zee OH sex
cut the spring out?
Old May 3, 2010 | 12:58 PM
tommie's Avatar
tommie
http://forums.corvetteforum.com/c5-t...-temp-tip.html
Old May 3, 2010 | 01:02 PM
zee OH sex's Avatar
zee OH sex
thanks tommie
Old May 3, 2010 | 01:11 PM
Fast Cop's Avatar
Fast Cop
If all you are looking to do is change your t-stat without a tune than save your money and leave the stock one in. You will not show any difference of max water temps with just a change of your t-stat.
I changed my t-stat to a 160 degree and had a tune to reset the fans and now my car has never gone over 195 degrees.
Old May 3, 2010 | 01:17 PM
corvettedaddy11's Avatar
corvettedaddy11
Upgrade rad stocker sucks!!!
Old May 3, 2010 | 06:23 PM
vettenuts's Avatar
vettenuts
Simple mod. Link
Note that I ended up using the 0.058" shim and the car runs pretty much at 180 on a cool night.
Old May 4, 2010 | 08:47 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
With a stock radiator and the stock thermostat shimmed .062, I cruised up I-95 last June from SC to CT with a constant 183-185 degree coolant temp.
I made the shim from .062 sheet Teflon using a leather punch.
Old May 4, 2010 | 08:16 PM
Bowtie_Brigade's Avatar
Bowtie_Brigade
I you have any need for heat, I'd stick with the 180 degree stat and tune your fans accordingly. 160 will be luke warm at best on a 40 degree or colder day.
Old May 4, 2010 | 09:47 PM
DARRYLZO6's Avatar
DARRYLZO6
Thanks!
I replaced the stocker with a 160 last summer from MAM. Also adjusted the fans with a Diablo tuner. MAM price is about $40. Its all good.
To Thermostat
