Bad harmonic balancer?
Old May 5, 2010 | 03:36 PM
slopoke17's Avatar
slopoke17
Default Bad harmonic balancer?
How can you tell when the harmonic balancer is going bad? I've never had to replace one in the 45 plus cars I've owned. This is for a 2004 Corvette with the LS-1 engine, just turned 41,000 miles. It sounded like a bird chirpping every time I stepped on the accelerator and stopped as soon as I took my foot off it.
Old May 5, 2010 | 03:47 PM
81c3's Avatar
81c3
Your symptom is common to balancer failure. Its either going to walk itself off the crank snub or the outer section thats bonded to the hub will start to fail and the outer section where the belt rides will wobble. Oil leaks around the crank snub are common for a walking balancer. Wobble is common as well as chirping sound if the outer section is loosening from the hub.
If the balancer looks steady with no wobbling. Check into the idler pulleys. They chirp too when failing.
Old May 5, 2010 | 04:09 PM
Bigg Dee's Avatar
Bigg Dee
My 98 is doing the same thing. the pully has a slight wobble to it. Is it safe to drive? Was hopeing to take a trip this weekend.
Old May 5, 2010 | 05:42 PM
81c3's Avatar
81c3
Personally, I wouldnt wander too far from home. Chances are youll be ok especially if you keep the revs down. Just my personal experiences that if something bad is going to happen, its at the most in opportune times. Maybe your luck is better than mine though.
Old May 5, 2010 | 06:10 PM
Bigg Dee's Avatar
Bigg Dee
aw man now im nervous, well I got aaa. Im only going 400 miles round trip. Maybe it will rain and I'll be forced to cancel, lol
Old May 5, 2010 | 11:07 PM
slopoke17's Avatar
slopoke17
Thanks for the help, I dropped it off at the local chevy dealer and they confirmed my suspicions. It will only set me back about $550.
Old May 5, 2010 | 11:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Paint a white line on the front of the balancer. Make sure it marks the outer ring abd hub.. Take the car for a frisky drive. Then examine the white line. If it isnt still lined up,,,your ballancer is TOAST. Sounds like you outer ring is no longer bonded to the hub
The Powerbond is a very good replacement!
Old May 6, 2010 | 04:43 AM
dieseldave56's Avatar
dieseldave56
Default Another reason.............
Another reason to keep a clean engine bay is that petroleum advances the deterioration of the rubber between the hub and outer ring. Heat and oils , then add the engine torque and accessory load.
81c3 gives a good description of symptoms. Bill's painted match line will be fool proof.
Ramification of complete failure or seperation would be 'bad'.
Old May 7, 2010 | 02:25 PM
Bigg Dee's Avatar
Bigg Dee
yep had to have mine changed, mechanic just finish, took $300 of my weekend party money. But at least I have piece of mind on that highway
Old May 7, 2010 | 02:49 PM
Pats90's Avatar
Pats90
St. Jude Donor '14-'15
Did they have to drop the steering rack to get it out?
Old May 7, 2010 | 02:51 PM
lucky131969's Avatar
lucky131969
No other way.....
Old May 7, 2010 | 03:21 PM
Bigg Dee's Avatar
Bigg Dee
awe man, he had the tires off, the rack off , there was stuff everywhere, I have a personal mechanic so he came to my house, took him two hours, $125 part and fluid, $175 labor cant beat that.
Old May 7, 2010 | 03:28 PM
lucky131969
Just curious, what parts did that include?
Old May 7, 2010 | 04:05 PM
Bigg Dee's Avatar
Bigg Dee
Just the balancer $117 $8 power steering fluid
Old May 7, 2010 | 04:19 PM
lucky131969
Hmmm...hopefully your personal mechanic knew not to reuse the factory bolt, and used an ARP bolt.....and used the correct torque procedure. If not, you may be revisiting this adventure in the not to distant future.
Old May 7, 2010 | 04:42 PM
Bigg Dee's Avatar
Bigg Dee
I hope so too, he works on another guys vette. Said he did it before. Whats the deal with the bolt?
Old May 7, 2010 | 05:55 PM
81c3's Avatar
81c3
Its a torque to yield bolt. That means it can only be stretched once. After that, the bolt cannot achieve the proper torque value again.
To Bad harmonic balancer?
Old May 8, 2010 | 03:34 AM
Bluefire's Avatar
Bluefire
Very true.
OP - When you are with the rack off changing your balancer, now is the best time to add a new cam. If not now, all of that stuff has to come out again to swap cams.
just sayin'
Old May 8, 2010 | 08:55 AM
slopoke17's Avatar
slopoke17
[QUOTE=dieseldave56;1573985418]Another reason to keep a clean engine bay is that petroleum advances the deterioration of the rubber between the hub and outer ring. Heat and oils , then add the engine torque and accessory load.
Funny thing my car didn't make any noise until after I degreased the engine and gave it a good washing. I wonder if that had anything to do with it?
Old May 10, 2010 | 04:34 PM
Bigg Dee's Avatar
Bigg Dee
I made the trip 450 miles with no problems, I asked about the bolt, my mechanic called the GM shop, he said that they said there was no problem using the same bolt. Said if I wanted to change it out they sell the bolt about $40 ( harden steel) He also said the GM guy said some corvette owners are fanatics, lol.. yes I am
