99 Coupe, ~ 430HP, Driveshaft upgrade??
Old 05-10-2010, 05:57 PM
Rex99Coupe
Support Corvetteforum!
Rex99Coupe's Avatar
Default 99 Coupe, ~ 430HP, Driveshaft upgrade??
I am about to add TR230 cam, Patriot stage 2 heads (milled to 59cc), roller rockers, underdrive balancer, LS7 lifters, LS2 Trays, LS2 chain, LS6 intake manifold and Monster level 2 clutch with tick adjustable master cylinder. I already have dynatech headers and blackwing intake. Anyone running approx. 430 HP have input on driveshaft, should I upgrade to newer while doing the clutch?
Old 05-10-2010, 05:58 PM
lucky131969
lucky131969's Avatar
Not necessary.
Old 05-10-2010, 06:05 PM
Rex99Coupe
Rex99Coupe's Avatar
Thanks Lucky, that's what I was hoping to hear.
Old 05-10-2010, 06:16 PM
lucky131969
But...since you have the driveline out, it's a perfect time to inspect the couplers.
Old 05-10-2010, 06:26 PM
Rex99Coupe
Rex99Coupe's Avatar
And while it's all apart should I replace the axle seals?
Old 05-11-2010, 10:26 AM
All_Motor_C5LS6
All_Motor_C5LS6's Avatar
No, just inspect the couplers. If you go with a larger driveshaft, you'll need the entire 01+ torque tube assembly.
To 99 Coupe, ~ 430HP, Driveshaft upgrade??
Quick Reply: 99 Coupe, ~ 430HP, Driveshaft upgrade??
