Air-tools?
Old May 24, 2010 | 12:10 PM
Solofast's Avatar
Solofast
Get a small air powered cutoff wheel from Harbor Freight. Right now they are on sale for $9.99, believe me that's the best 10 bucks you will spend on a tool.... You will be amazed how often you use it.
I also have a die grinder, the 3/8's rachet and a 1/2 inch impact, but the impact is almost worthless since it won't loosen lugs that are properly torqued. All of the other tools are chepo, but you want the better impact for sure.
I bought a 3.5 cfm Sanborn oilless compressor (like the powermate) with the 6 gallon tank 25 years ago and it is still working just fine. I don't use it a whole lot, but it seems that every week or so I crank it up and air tires or some other odd job. Once I was using it do die grinding on some aluminum parts and used it like crazy for a couple of weeks. For $179 it is all you need if you aren't trying to use it every day. If you aren't going to making your living with it, I'd be hard pressed to spend more than $200 for a compressor.
Old May 24, 2010 | 03:53 PM
jasonlouis2217's Avatar
jasonlouis2217
Originally Posted by lucky131969
Only you can answer that question. It's better to tell us how much you are willing to spend, and then we can tell you what you can purchase, based on your budget.
I wanna spend 300-500 to "start" my air-tool set.
Old May 24, 2010 | 04:06 PM
hotwheels57's Avatar
hotwheels57
I would suggest you get your air tools at SEAR'S. I bought cheap air tools initially (darn HARBOR FREIGHT) and they all inevitably failed. And their failure was always when I was in the middle of a project. Drop everything, clean up and drive to find a replacement tool is a pain.
SEAR'S tools have not failed me now in five years. If they do, they're open 7 days a week. My most used tools are 3/8" butterfly ratchet, cut off and 1/2" impact. I seldom use the other 3/8" ratchet tool. A 3/8" drill and a 3/8" angle drill are also nice to have. I have also purchased a few tools from HOME DEPOT with good results.
My first compressor was a 5hp/33 gallon/110v which was always running when I was using my air tools. I eventually bought a 6hp/60gallon/220v HUSKY from HOME DEPOT. It's got the air capacity/cfm so it's not always running. It's been used daily now since 2000 w/o a problem.
Old May 24, 2010 | 04:11 PM
rebelheart's Avatar
rebelheart
Hate to tell you this but Sears, and home depot sell the same off shore brands as harbor freight and even Ingorsal Rand isnt american made anymore.
Old May 24, 2010 | 04:33 PM
k0ts's Avatar
k0ts
I have not had good luck with oil-less compressors... They are noisy and just don't last...
You're mileage may vary... They are probably fine for blowing up tires...
Old May 24, 2010 | 04:45 PM
dougbfresh's Avatar
dougbfresh
Had my last SEARS 11 gal for years, even painted cars with it (ran all the time while I was doing it), I upgraded to a 33 gal and the guy I sold the 11 gal to is still using it.
If your running a shop and have a high air demand you most likely don't want oil-less but for most anything a DYI guy need to do oil-less if fine and cost effective.
Old May 24, 2010 | 04:53 PM
wcsinx's Avatar
wcsinx
Your point? China builds exactly what we tell them to. Compare that trash at H.F. with an Ingersol Rand or Craftsman. It's obvious that there's a difference in quality. Just because it's from China doesn't mean it's all the same stuff.
I have a 12 gallon reed valve, oilless Craftsman compressor. Over the past 5 years I have torn down and rebuilt 3 cars' suspensions (including a 33 year old C3), installed 2 full exhaust systems, pulled off countless lug nuts, inflated countless tires, and painted a car. Yes it's noisy. If you have the money, the room, and plan on using it on an almost daily basis, then absolutely get a piston compressor. For the other 99% of us, a reed valve compressor is 100% adequate.
Old May 24, 2010 | 05:16 PM
lionelhutz's Avatar
lionelhutz
I've done stuff like used a D/A sander and sanded the garage walls to re-paint them so the little oil-less compressors are useless to me. I had the tank on my 60 gallon upright so hot I could hardly touch it.
Have aluminum wheels? Try putting an arbour or cut-off wheel adapter with a 6" polishing wheel into a die grinder because it works great to polish natural finish wheels. But, just see how long that little compressor lasts running an hour or 2 at a time.
Peter
Old May 24, 2010 | 05:26 PM
dougbfresh's Avatar
dougbfresh
Old May 24, 2010 | 05:34 PM
k0ts's Avatar
k0ts
Originally Posted by dougbfresh
Sorry, but I've seen two of them die.. I guess you guys were lucky
or maybe I have a cloud over me...
Old May 24, 2010 | 05:38 PM
chevylad's Avatar
chevylad
I really like my Ingersol Rand stuff, tools and compressor. I'd get one of the little air hand held sawzalls. I redid a roll bar in another car and that little saw was small enough to reach in the corner and cut off a 1 3/4 inch roll bar tube.
Old May 24, 2010 | 10:19 PM
jasonlouis2217
Ok, got an idea of what tools I should get. What is a good "starter" compressor, hp/gal/psi ? Again for most DIY projects. Thanks for any suggestions.
Old May 24, 2010 | 10:30 PM
  #33
sami85L98's Avatar
sami85L98
I use IR 2135TIQMAX, 1/2" drive and its 700 ft lbs busting torque, its quiet and amazing gun i ever used so far. also i have 3/8" drive IR gun but dont use much, 3/8" IR reactionless ratchet cant beat these IR tools. For the compressor central pneumatic sells buy HF get the 21 gallon 3 HP 4.9 cfm @90 psi more than enough.
oh my 1/2" IR quiet impact gun weighs only 3.9 lbs. Get 1/2" IR Ti gun and rest you can buy cheap one's and dont forget the 1/2" drive Swivel impact socket set man they are awesome.
Old May 24, 2010 | 10:46 PM
  #34
postwhore's Avatar
postwhore
Your point? China builds exactly what we tell them to. Compare that trash at H.F. with an Ingersoll Rand or Craftsman. It's obvious that there's a difference in quality. Just because it's from China doesn't mean it's all the same stuff.
I have 3 compressors
A tiny reed valve one for filling tires and travels in the race trailer ( for trailer and pit bike tires, the cars get nitrogen ) and 2 belt driven for the real work
My belt drives have been running for 20+ and 10+ years are still running/working great and have been wired in 24/7
I change the oil once a year ( Mobil 1 )
You can get a decent starter set of air tools at Lowe's or HD for under 200 bucks
Keep em oiled and they usually last just fine for a home mechanic .
When you decide if you are going to get serious , then upgrade as needed.
For example , I have 2 1/2" guns ,my CP ( the old REAL Chicago pneumatic , not the new CP crap ) is 30+ years old and the Blu-Point is 20+ and they still work perfectly.
I bought the best tools I could get at the time and most are 20-25 years old or more w/o any problems.
Cheapo tools will not last that long but they may be all you need depending on workload.
I bought a 15 dollar 3/8's air ratchet from Harbor Freight ( HB is 10 minutes from the track ) when I forgot mine at home , it's lasted 10 years so far .
It is not a "polished" as my good IR but it works just fine actually, again , I keep it oiled.
Old May 26, 2010 | 01:19 PM
  #35
rebelheart's Avatar
rebelheart
I use Snapon and IR tools at work,at home my harbor freight tools have lasted up to 10 years,but if I need to do any heavy stuff I take it to the shop.For the average home tech they do just fine within reason.
Old May 26, 2010 | 01:21 PM
  #36
TurboBerserker's Avatar
TurboBerserker
Best air tool for the money: a large diameter air hose. Get a 1/2 inch hose...
Old May 26, 2010 | 02:46 PM
  #37
chaase's Avatar
chaase
St. Jude Donor '12
I bought an inexpensive set of air tools from HD and they work just fine. They don't get used constantly like my friend the mechanic so they are lasting.
I have a Sears 33 gallon vertical compressor that I have had for a few years. It tucks in a corner of the garage nicely and I have used it for everything from swapping the rims/tires on my Vette for racing events to powering a nailer for various wood working things around the house.
To Air-tools?
Old May 26, 2010 | 09:13 PM
  #38
rebelheart's Avatar
rebelheart
TurboB is right,it makes a huge difference with 1/2 hose.
Old May 26, 2010 | 10:44 PM
  #39
Dave68's Avatar
Dave68
I spent qute a bit of time looking for a quiet compressor that didn't cost $$800 or more. MOST oilless compressors are very noisy, but there IS one that is both durable and fairly quiet.
I found a used one for $300. It puts out enough air flow for many 1/2-inch impact wrenches but some wrenches are real air hogs. Choose accordingly.
Old May 27, 2010 | 12:57 AM
  #40
postwhore's Avatar
postwhore
great for some things but hard to handle
