Air-tools?
Old May 24, 2010 | 01:23 AM
jasonlouis2217's Avatar
jasonlouis2217
Default Air-tools?
I would consider myself pretty mechanically inclined, and I enjoy working on my car myself. I have a decent amount of hand tools I've accumulated over the years. Just recently recieved my income tax and have some $ to play around with. Looking at an air-impact tool set, I won't be swapping out tranmissions or engines, general bolt on stuff and maintenance, what should I look at getting, if any?
Old May 24, 2010 | 02:15 AM
Last C5's Avatar
Last C5
Buy a good, maybe Ingersaul Rand, adjustable standard 1/2" impact gun and a cheap 3/8" air ratchet.
Old May 24, 2010 | 02:25 AM
postwhore's Avatar
postwhore
Originally Posted by Last C5
Buy a good, maybe Ingersoll Rand, adjustable standard 1/2" impact gun and a cheap 3/8" air ratchet.
and a 3/8" gun and 1/4 " air ratchet
for compressors , bigger is better
Old May 24, 2010 | 02:49 AM
jasonlouis2217
What's a reasonable amount I should be spending?
Old May 24, 2010 | 08:00 AM
c5chines's Avatar
c5chines
I get more use out of my 3/8" butterfly than my 3/8" ratchet, but both are handy. A 1/2" impact is good too along with quality impact sockets (deep and regular) in 3/8" and 1/2". As long as you are using air, get a air powered pop rivet gun too. They make it easy to set heavier rivets without breaking your hands. A small die grinder is nice too.It really depends on what you are working on regularly as far as air tools go. There is usually a comparable electric tool available and air is usually the most expensive option to buy and run.
Old May 24, 2010 | 09:02 AM
rebelheart's Avatar
rebelheart
For the light duty/home mech,just buy some harbor freight tools.
Old May 24, 2010 | 09:13 AM
dougbfresh's Avatar
dougbfresh
Get an impact with the MOST reverse torque you can afford. Decent Air rachet, couple of blow guns and maybe an air chisel.
Old May 24, 2010 | 09:16 AM
j84buick's Avatar
j84buick
Agreed. In Vette and Corvette fever they always have a ad with a 20% a single item coupon. The one tool to invest in is the 1/2" impact wrench. Don't get the $35 one and don't get the $200 one. Get the good one for $90 or so and it will serve you well in the garage.
Old May 24, 2010 | 09:52 AM
bumble-z's Avatar
bumble-z
Make sure you get an air tool that will have enought torque to loosen/tighten the axle hub nut.( 118 lb.ft) and caliper bracket bolts. (125 lb.ft.
Old May 24, 2010 | 09:57 AM
wcsinx's Avatar
wcsinx
I'd blow it all on the biggest & best compressor you can afford, and then aquire tools later as the needs arise.
Old May 24, 2010 | 10:22 AM
corvettebob1's Avatar
corvettebob1
For the 1/2" impact get the CP 749, compact and light 5.5lbs yet powerful and dependable.
$149.00 on the ebay.
Old May 24, 2010 | 10:38 AM
kg54trains's Avatar
kg54trains
The question can be discussed with the point of purchase. The type of work and the amount of work completed is a big consideration. If you are a DIY on light to medium jobs a 175. to 250. price range is good for the compressor. Just check the recommended usage with the compressor you are looking to buy. Just do not buy a compressor that is not intented to run air tools. There are small compressors designed to operate tools that shoot nails, fill tires, etc.
Old May 24, 2010 | 11:25 AM
lionelhutz's Avatar
lionelhutz
Basically, look for a compressor that holds oil and has a real crank shaft and real pistons. Most likely it will be belt driven by the motor. The direct direct drive compressors are noisy and don't pump much air and don't last.
You do want a good 1/2" impact or else it won't have the ***** to loosen the tough bolts and you end up using a breaker bar to start with which defeats the whole purpose of having it.
Peter
Old May 24, 2010 | 11:37 AM
postwhore's Avatar
postwhore
I really like my rivet gun .
Die Grinders are great .
Air chisels are fun too.
I also like my air drill.
I rarely use a butterfly anymore though since I haven't replaced my airline swivel.
Air tools can become an addiction
Old May 24, 2010 | 11:39 AM
dougbfresh's Avatar
dougbfresh
Peter
BS, I have and have had direct drive oil-less compressors for years. Last one I had is still running for the guy I sold it too. If your using it like most DYI guys, an oil-less is a perfect compressor. All you have to do is drain the water out of the tank every so often.
Old May 24, 2010 | 11:40 AM
postwhore's Avatar
postwhore
a good reminder for all , you have to drain them periodically
Old May 24, 2010 | 11:47 AM
wcsinx's Avatar
wcsinx
I just leave the drain ever so slightly cracked open. It takes about a day for it to fully leak down.
To Air-tools?
Old May 24, 2010 | 11:50 AM
lucky131969's Avatar
lucky131969
Only you can answer that question. It's better to tell us how much you are willing to spend, and then we can tell you what you can purchase, based on your budget.
Old May 24, 2010 | 11:51 AM
wcsinx's Avatar
wcsinx
Piston compressor is way overkill for most people. If you're talking about using an air tool a couple times a month, then a reed valve compressor is completely adequate, and will actually be less maintenance with that sort of usage. I've painted a car with my 12 gallon reed valve compressor for that matter.
Old May 24, 2010 | 12:07 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default torque stick
Put one of these on your list,http://www.torquestick.com/ they work well and save a lot of time checking and tightening lugs.
