Lifter install?
Old Jun 28, 2010 | 11:34 PM
Z0GOON6's Avatar
Z0GOON6
Default Lifter install?
do the heads have to be removed to install new lifters? and are c6 z06 lifters a good lifter for a cam swap in a c5z? and are they the same height as the stock ones so pushrod lengths wouldn't have to be changed? anything else recommended to change with lifters?
Old Jun 28, 2010 | 11:41 PM
lucky131969's Avatar
lucky131969
Yes.
Old Jun 29, 2010 | 05:33 AM
vettenuts's Avatar
vettenuts
Is there a reason you are changing lifters?
Old Jun 29, 2010 | 05:57 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
All depends on the cam and springs being used and rpms that it will run
Old Jun 29, 2010 | 08:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes the heads nee to be removed. If you have an early C5, it is recommended that you also change the plastic lifter trays to the newer design.. If they have a 10 on the bottom of the tray, its the old version.
I agree. Why are you changing lifters?
Old Jun 29, 2010 | 08:53 AM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
not to hijack but do you know the part number for the trays??
Nevermind- LS2 Trays 12595365
Old Jun 29, 2010 | 01:44 PM
Z0GOON6's Avatar
Z0GOON6
just thought it would be a good idea? its a 01 z06 with around 2500 miles
Old Jun 29, 2010 | 01:57 PM
lucky131969
2500? They are just broke in
Old Jun 29, 2010 | 02:22 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I pulled my 02 ZO6 lifters out for a Heads/Cam/ FAST 90 upgrade and they looked new after 50,000 miles of giving it hell.
I did up grade to Caddy racing lifters only because I installed an agressive high lift cam and high seat pressure springs.
On a mostly stock application or mildly modified LS engines, changing lifters will NOT give you any advantage or added HP.
On a later model 1999+ C5's, it already has the up-dated lifter trays.
Old Jun 29, 2010 | 07:18 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree too!!! 2500 miles... wow, they are still brand new. I ran mine till 274K miles before at least one, possibly two started failing. I then replaced all of them, pushrods, springs, seals, rockers, all at the same time.
To Lifter install?
