C5 headlight operation issue
Old Jul 17, 2010 | 08:50 AM
unworthy's Avatar
unworthy
4th Gear
Default C5 headlight operation issue
I would appreciate some guidance.
When I turn the headlight switch to the "parking light" position, the headlights open but do not turn on (rather than waiting to open in the headlight position on the switch).
In the headlight "on" position all is correct.
When the lights are turned off, the passenger light door continues to attempt to shut for 7 seconds after being completely down, making a machine gun like noise before turning off.
Finally, I unplugged the passenger headlight and the drivers light works as it is supposed to, meaning, it comes up when the switch is in the "headlight position".
Where is my problem?
Old Jul 17, 2010 | 08:56 AM
rebelheart's Avatar
rebelheart
For starters your right headlight door gear is stripped and needs to be replaced.
Old Jul 17, 2010 | 09:08 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with the gears needing to be replaced.
Old Jul 17, 2010 | 09:24 AM
GEMcLean's Avatar
GEMcLean
http://forums.corvetteforum.com/c5-t...iy-thread.html
Number 23
Old Jul 17, 2010 | 09:35 AM
DeeGee's Avatar
DeeGee
and worn gears have been known to cause the "up but off" at park glitch.
Old Aug 12, 2010 | 08:49 PM
unworthy's Avatar
unworthy
4th Gear
sorry for the delay in response-I replaced the gear and the "up but off" issue corrected itself also. thank you everyone.
To C5 headlight operation issue
