Header studs alternative
Old Jul 23, 2010 | 09:58 PM
enos44's Avatar
enos44
Default Header studs alternative
Just wanted to share some info regarding header studs. If you don't really want to spend the extra $100 on ARP header studs, GM makes some for I believe the 4.3L V6. The part number for the studs is 11589154 and they are just under $2.00 a bolt (come in packs of 5). I had some metric nuts laying around so I'm just using those. I believe the size of those is M8-1.25.
Old Jul 23, 2010 | 10:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you found that the header STUDS are better than the bolts?? I use to own a turbo Volve and it had manifold STUDS. Please let me know what your expierencies are between studs and bolts.
Sounds like a potential up grade.
Bill C
Old Jul 24, 2010 | 12:18 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
They make it easier to install the gasket and headers
I run them on my car
Old Jul 24, 2010 | 10:28 AM
enos44's Avatar
enos44
Bill: I haven't installed them yet, but the main reason behind me going to studs was simply for ease of installation. In the 16 months I have had my LG longtubes I have had them in and out about 10 times haha. Plus I live in California where I have to swap my stock manifolds back on for smog. I will let you know how they work out.
Old Jul 24, 2010 | 11:15 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
i put them on my car when i rebuilt the motor.
WELL worth the money. You can slide the gasket on then put the header up and get a nut started. No messing around trying to get the gasket to stay on the bolt and then hold the header while threading it in place!!!
$100 is salty for what they are, but they were worth it in my mind.
Old Jul 24, 2010 | 01:03 PM
corvettebob1's Avatar
corvettebob1
All you neeed is 4 studs, Ace hardware black anodized are hardened to over grade 8.
Only a couple of bucks, use in front and rear bolt holes only works perfect.
Old Jul 24, 2010 | 01:34 PM
99blancoss's Avatar
099blancoss
Former Vendor
The only thing I dont like about they black is they rust. The ARP polished are spendy no doubt but they look sharp and if that is important to a person its something to think about.
Old Jul 25, 2010 | 09:59 AM
corvettebob1
Mine have only been on for ~6 months and no rust yet I don't think they will because as I noted they are black anodized.
Old Jul 25, 2010 | 10:02 AM
hattitude's Avatar
hattitude
I did my header install by myself and they helped a lot.....
Old Jul 25, 2010 | 10:36 AM
blazer427X3's Avatar
blazer427X3
Great suggestion ! I think I will give the Ace stud / bolt combo a try when I put my headers back on.
Okay to use anti-seize on the studs, nuts and bolts ?
Old Jul 25, 2010 | 01:32 PM
99blancoss's Avatar
099blancoss
Former Vendor
Sorry thought you were talking about the typical black that hardened bolts come in. I havent seen anodozed bolts at my hardware store.
To Header studs alternative
