Six-Speed Trans Fluid?
Old Jul 25, 2010 | 10:34 PM
TonyVette396's Avatar
TonyVette396
Default Six-Speed Trans Fluid?
I have a '99 with manual trans. I've heard about the paper blocker rings and how synthetic fluids will ruin the trans. But I've also heard some synthetics won't harm the paper blockers. I like Amsoil products, so is there a synthetic fluid they produce that will work?
Old Jul 26, 2010 | 08:33 AM
c3andc5's Avatar
c3andc5
That is one of the biggest myths propagated on this forum. I have a 2000 w/6-spd manual and have had Mobile 1 synthetic ATF in my tranny for over 50k miles now with no issues whatsoever. Your manual recommends DEXRON III ATF. No mention of any warnings against using synthetic. I would never do anything risky on my C5 and I have zero concerns about using synthetic ATF.
Old Jul 26, 2010 | 11:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Used Mobile 1 synthetic in my 98 MN6 without ANY ILL effects. It shifted MUCH better.
BC
Old Jul 26, 2010 | 02:56 PM
Venomous's Avatar
Venomous
The factory syncromesh installed in C5s is a partial synthetic and works great. The new transfer case/ transmission fluid GM has is pretty good as well.
Old Jul 26, 2010 | 03:14 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
I use regular dextron 3 atf in t56's, stock or built. I have not seen a reason to switch.
Old Jul 26, 2010 | 07:28 PM
Solofast's Avatar
Solofast
I recently spoke with some engineers from Tremec and they recommened the new Penzoil "Syncromesh" tranny fluid. They said it was specifically designed for this particular transmission...
Old Jul 26, 2010 | 07:57 PM
rich goepfrich's Avatar
rich goepfrich
Thanks, thats good to know.
Old Jul 26, 2010 | 11:59 PM
Carcass's Avatar
Carcass
I used Mobil 1 ATF in my '98 MN6 for about 6 months,and it didn't really help the shifting at all-it was "clunky" or "notchy" going into any gear,so I decided to go with what the tag on the fill plug said,drained the Mobil 1,and filled it up with Valvoline Dexron III (the cheap stuff).and it's been shifting like a Vette should every since.
I may be an isolated case,but my tranny definitely did not like the Mobil 1.
Old Jul 27, 2010 | 09:29 AM
Corvette Don's Avatar
Corvette Don
Thats what I use
Old Jul 27, 2010 | 10:59 AM
TonyVette396
Nobody uses Amsoil fluid???
Old Jul 27, 2010 | 12:08 PM
oh1vette's Avatar
oh1vette
Old Jul 27, 2010 | 12:14 PM
AU N EGL's Avatar
AU N EGL
M1 ATF and M1 gear oil in the diff ( with anti slip )
Old Jul 27, 2010 | 01:31 PM
johnson-rod's Avatar
johnson-rod
I have a '98 6 speed.
I switched to Amsoil ATD over two years ago.
It shifts like "budda".
Old Jul 28, 2010 | 09:14 AM
Rickyh93's Avatar
Rickyh93
I use the AMSOIL ATF in my 01 Z with the RPM Level 5 tranny - no issues.
Old Jul 28, 2010 | 11:36 AM
TonyVette396
Thanks for all the input. I'm gonna try the Amsoil ATD.
Old Jul 28, 2010 | 11:48 AM
dbaker's Avatar
dbaker
I run Amsoil ATD in the trans(02Z) and Amsoil 75-90 Severe Gear in the diff.
Change 'em both while you're at it.
\db2
Carolina
Old Jul 29, 2010 | 12:37 AM
flynhi's Avatar
flynhi
I spoke with Dale at Tremec and he recommended Dexron III or Mobil 1for my July 98 built 99 M6. Manual trans installed at that time were built by Borg Warner which was later bought out by Tremec. The BW trans have paper blockers.
GM TSB states that vehicles previously using Dexron III should now use P/N 88861800 Labelled Manual Transmission and Transfer Case Fluid.
My local speed shop recently installed Amsoil ATF and I immediately began to experience a gear whine when shifting around 3,000 RPM.
So I'm changing to the new GM P/N.
To Six-Speed Trans Fluid?
Old Jul 29, 2010 | 12:47 AM
thechosenone's Avatar
thechosenone
Im with this guy!
Old Jul 29, 2010 | 12:56 AM
flynhi's Avatar
flynhi
Originally Posted by Z 0 SICK
Im with this guy!
GM no longer sells Dexron III and I've read that the H spec that other brands sell does not match the H spec that GM's Dexron III met. In other words, the after market Dexron III is not the same as GM's was.
So, where do you folks buy Dexron III that is equal to GM's?
Tks for your replies.
Old Jul 30, 2010 | 12:29 AM
striper's Avatar
striper
I use Royal Purple Synchromax. It is a fluid made for manual transmissions that usually would use auto trans fluid. It improved the shifting of my car.
