I need help
Old Aug 11, 2010 | 02:01 PM
cachorro's Avatar
cachorro
Cruising
Default I need help
Maybe my English is not very fluid, but I try to understand, I need help please I have a problem with my corvete C5 model 2001, and I have the annoying code 1214 ABS, but my car when accelerated it with the brake pressed to do a burn out I that up 1500 rpm, engine so goes there and as if traction control, someone I could say as remove traction control do burn out and out the more fast in a quick exit. Thank you all for your help.
Old Aug 11, 2010 | 02:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Lets see if I can help you. I fully understand this part of your statement:
"Maybe my English is not very fluid, but I try to understand, I need help please I have a problem with my corvete C5 model 2001, and I have the annoying code 1214 ABS, but my car when accelerated it with the brake pressed to do a burn out I that up 1500 rpm"
Sounds like your trying to do a power brake. Foot on brake and depress the accelerator and then you release the brake to spin the tires. Am I Correct?
That Code means that you need to remove the electrical module EBTCM on the Brake Pressure Modulator Valve and send the module to one of the people here in the USA that repairs that module. Normaly people use ABS FIXER but there are others that do the same work. ABS Fixer charges $150. USD to repair that electronic module.
When you get that DTC, you default to normal unassisted braking. You will not have Active Handling, Anti Lock braking or traction control.
The rest of the post is lost in translation.
Do you have ANY other DTCs???? If so, please list them.
SUGGESTION. Try writing the request for help in your native language and put it under the english translation. Im sure that someone will be able to translate the meaning of the part of the post that we cant understand your meaning. What language do you speak?
Bill
Old Aug 11, 2010 | 02:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just figured out that you speak Spanish. Post the problem in spanish and I sure that someone will be able to translate for you.
Old Aug 11, 2010 | 02:34 PM
cachorro's Avatar
cachorro
Cruising
si efectivamente yo hablo español, mi problema es que quiero poder calentar mis llantas o hacer un burn out con el corvette, pero cuando tengo el freno pisado y acelero para que empiecen a girar las llantas y calienten, el coche llega a las 1500 rpm del motor y de ahi para arriba como si cortara el motor y no patinan las llantas, hay algun fusible o relay que pudiera quitar para eliminar esto y poder hacer patinar mis llantas ?
Old Aug 11, 2010 | 02:51 PM
dougbfresh's Avatar
dougbfresh
Turn off the traction control.
Old Aug 11, 2010 | 02:52 PM
PetersC5's Avatar
PetersC5
Microsoft translated.......
If Spanish I actually speak, my problem is that I want to be able to warm up my tires or do a burn out with the corvette, but when I have the crushing brake and accelerated start spinning wheels and hot, the car arrives at 1500 rpm of the engine and there above as if cut the engine and not patinan wheels, is there a fuse or relay that could remove to remove this and be able to skate my tires?
Sounds like he is rying to do a burnout and when he hits 1500 RPM the engine cuts out or the Active handling / Traction control cuts in thinking the cars out of control.
Try turning off active handling.....beyond this im lost to translation
Old Aug 11, 2010 | 02:56 PM
cachorro's Avatar
cachorro
Cruising
el boton del active handling no funciona, tengo prendido el foco del tablero del abs y el del active handling
Old Aug 11, 2010 | 03:09 PM
dougbfresh's Avatar
dougbfresh
If you have a current 1214 code, code to www.absfixer.com and get the instructions from removing the EBCM, send the module to him for repair.
Old Aug 11, 2010 | 03:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Remember. He has a DTC 1214 CODE.. So, he will not have control of the traction button.
Have the module repaired and see if that solves the problem that your having. When the module is removed for repair, you can still drive the car but you will NOT have any electronically assisted braking.
To I need help
