cam specs question
Old Aug 11, 2010 | 03:18 PM
racerwannabe's Avatar
racerwannabe
St. Jude Donor '06
Default cam specs question
i want to run a comp thumper cam in my 2001 corvette...auto matic...will the stock heads work or will I have piston to valve clearance problems from my other wise stock motor???
Johnny
Old Aug 11, 2010 | 04:31 PM
Bluefire's Avatar
Bluefire
I am running stock 243 heads. My cam is 224/230 .585/.595 113. with no p/v clearance issues. My understanding is (real motor guys correct me if I am wrong ), any lift < .600 will not encounter p/v issues.
Hope that helps.
Old Aug 11, 2010 | 06:32 PM
vettenuts's Avatar
vettenuts
Total lift is not really relevant. What determines PTV is the duration and ramp rate. If the OP wants more responses, he should really post the cam specifications.
Old Aug 12, 2010 | 09:10 AM
dankhts's Avatar
dankhts
duration and ramp rate count! especially if the heads have been milled!
Old Aug 12, 2010 | 02:23 PM
racerwannabe
St. Jude Donor '06
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT: .554 .537
DURATION AT
.006 TAPPET LIFT 275 295
VALVE TIMING OPEN CLOSE
AT .006 INT 33 62
EXH 77 38
THESE SPECS ARE FOR CAM INSTALLED
@ 103.0 INT C/L
INT EXH
DUR @.050: 219 233
LOBE LIFT: .3260 .3160
LOBE SEPARATION: 109.0
now ....will it fit without cutting the pistons???
Old Aug 12, 2010 | 03:48 PM
AU N EGL's Avatar
AU N EGL
Looks like a
219/233 554/537 109
Old Aug 12, 2010 | 03:52 PM
racerwannabe
St. Jude Donor '06
Originally Posted by AU N EGL
Looks like a
219/233 554/537 109
do you think i can use it??
Old Aug 12, 2010 | 04:23 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I'm running a 237/242 .609 112LSA on stock 241 heads with no problems.
Old Aug 12, 2010 | 04:47 PM
AU N EGL's Avatar
AU N EGL
no problems
Old Aug 12, 2010 | 06:17 PM
cptinjak's Avatar
cptinjak
Stock heads? definitely
Stock springs? ehhh...
Old Aug 12, 2010 | 06:32 PM
AU N EGL's Avatar
AU N EGL
I also would not use stock springs
Old Aug 12, 2010 | 08:34 PM
vettenuts's Avatar
vettenuts
Should clear but I would still measure for two reasons. You will know how much clearance you have and if you ever decide to do something else (for example mill heads) you won't be guessing later.
Old Aug 13, 2010 | 10:48 AM
racerwannabe
St. Jude Donor '06
will do..and will get the kit..springs retainers rockers etc..
thanks guys!!
Johnny
To cam specs question
