What is it?
Old Aug 11, 2010 | 07:43 PM
Dale002's Avatar
Dale002
Default What is it?
I posted this on the C6 intead of C5.
In my album I have a picture of something I found while looking under the hood.
It was laying on top of the right lower arm.
What is it? It look like it still has a vacum line still attached to it.
Old Aug 11, 2010 | 08:34 PM
YNOT2K's Avatar
YNOT2K
a red X?
Old Aug 11, 2010 | 08:43 PM
00Corvette's Avatar
00Corvette
pic don't work man
Old Aug 11, 2010 | 08:44 PM
Dale002's Avatar
Dale002
Can you guys look in my Album?
Old Aug 11, 2010 | 08:45 PM
00Corvette's Avatar
00Corvette
dude, the pic is like 1 inch by 1 inch...i can't tell, post it bigger somehow
Old Aug 11, 2010 | 08:48 PM
00Corvette's Avatar
00Corvette
http://forums.corvetteforum.com/help...es-thread.html
Old Aug 11, 2010 | 09:00 PM
Dale002's Avatar
Dale002
Check it out now. I resized it to 800x600
Old Aug 11, 2010 | 09:02 PM
vettenuts's Avatar
vettenuts
Link?
Old Aug 11, 2010 | 09:04 PM
Dale002's Avatar
Dale002
Default 00Corvette
Thanks man, That's great.
I'll go in that direction since I'm sure I'll be posting many other pictures.
Old Aug 11, 2010 | 09:07 PM
Dale002's Avatar
Dale002
Default vettenuts
Originally Posted by vettenuts
Link?
If you are thinking of the sway bar link,It's not.
I 've looked at the links and while they need replacing I don't think is it.
It has a hose attached to it.
Old Aug 11, 2010 | 09:16 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
The entrails of a Mustang devoured by your vette?? OK maybe not.
Old Aug 11, 2010 | 09:50 PM
Dale002's Avatar
Dale002
OK Got it done.
Maybe it will help.
It's by the a/c compressor.
Old Aug 11, 2010 | 11:48 PM
Dale002's Avatar
Dale002
I think It's a broken front right wheel position sensor or sensor link for the RTD system.
Old Aug 12, 2010 | 02:00 AM
00Corvette's Avatar
00Corvette
It's probably not related to the Wheel speed sensor. this comes directly out of the back of the hub itself..
I'll have to look underneath mine tomorrow if no one post up before. sorry i can't be of more help atm
Old Aug 12, 2010 | 12:52 PM
Dale002's Avatar
Dale002
Well,
It's not the link or sensor on the RTD system as everything there looks good.
Plus the system works with no code.
Old Aug 13, 2010 | 10:51 PM
Dale002's Avatar
Dale002
It's what left of the connection to the front shocks.
This car has the RTD system F45 suspension on it however the front shocks have been replaced to stock shocks.
I bought this car recently and whom ever had it before me must had ripped them off the F45 shocks and just laid them out of the way. Both front are the same while the rear still have the F45 shock on. I'll be replacing all the shocks soon to Z06 type or something.
I suspect the car will be limited to 80mph in it' current configuration.
I'll have to buy the simulators as well.
I've been told there's a cheaper way to simulate it but,I haven't found that info here yet.
Old Aug 14, 2010 | 03:45 PM
00Corvette's Avatar
00Corvette
Dale,
I'll bet that's it man..it looked like a magnet kind of to me. if you're car used to or still has the magnerhetorical suspension or the adjustable one...I'll bet if you had the shocks replaced that wire is no longer needed.
If you don't have codes I'd expect this even more.
Just zip tie it off for now.
Old Aug 14, 2010 | 07:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks like some one removed the control valves from the F-45 shock and retained the coil assy so that the system is happy and doesn't throw DTCs. SO,, you have regular shocks and still retain the old control coil to make the RTD computer happy. Not a bad Idea.
If I were you, I would have the RTD system de-programmed out and get rid of all that crap. Your rear shocks are most likely SHOT!
BC
Old Aug 14, 2010 | 09:07 PM
Dale002's Avatar
Dale002
That's the plan.
To What is it?
