Busted Drive shaft?
Old Aug 13, 2010 | 04:28 PM
cgm12mgc's Avatar
cgm12mgc
Got her open and out came a birds nest! The front coupling destroyed it's self bit the drive shaft is great. The bolts going through the coupling snapped swell so I will replace bearings couplings and bolts all around. She'll be up and running again as soon as I get the new parts in the mail
Pictures to come tonight
Old Aug 13, 2010 | 05:25 PM
00Corvette's Avatar
00Corvette
thanks for posting these pics man
Old Aug 13, 2010 | 08:06 PM
cgm12mgc's Avatar
cgm12mgc
Old Aug 13, 2010 | 08:07 PM
cgm12mgc's Avatar
cgm12mgc
does anyone happen to have the part number for those bolts?? i am in need...
Old Aug 13, 2010 | 08:29 PM
lionelhutz's Avatar
lionelhutz
Wow, that just slipped by to not break the ears on the middle shaft. Still, those ears have taken quite a beating.
Hopefully, you'll get it together OK and it'll work well.
Peter
Old Aug 13, 2010 | 08:59 PM
cgm12mgc's Avatar
cgm12mgc
yeah i was looking at those ears and they do have some dammage, im an airframe mechanic so ill take them into work and xray the ears to see if there are any cracks... otherwise im going to reuse them... on another note does anyone know the part number for the 10mm bolts that go into the coupler? i need all new ones...
Old Aug 13, 2010 | 10:26 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
If no one comes through with the bolt part numbers for you I'll get them for you on Monday morning.
Old Aug 13, 2010 | 10:51 PM
cgm12mgc's Avatar
cgm12mgc
Sounds good i appreciate it
Old Aug 14, 2010 | 12:25 PM
Corvette Don's Avatar
Corvette Don
Mine is a 2000 with 440 RWHP, I am adding 3.90 gears to mine in about a week, I think I am going to pull mine apart and replace my bushings, I would hate for this to happen to me. What base are you at?
Old Aug 14, 2010 | 12:46 PM
cgm12mgc's Avatar
cgm12mgc
Yeah it's deffinatley a good idea. I have taken the car apart before but never the tq tube.... Never crossed my mind that there are rubber bushings in it... But lessons learned now anytime I do a clutch swap I'm going to replace these guys too
I'm at cherry point in North Carolina, you?
Old Aug 14, 2010 | 12:48 PM
lionelhutz's Avatar
lionelhutz
Search is your friend...
P/N 12456213
Peter
Old Aug 14, 2010 | 01:46 PM
Paul 75 L82's Avatar
Paul 75 L82
Great thread, great pictures. I'm getting ready to do a trans/clutch change out so I'm going to go ahead and change out the couplers. I probally won't change out the bearings. Thanks for the pictures and the bolt part number.
Old Aug 14, 2010 | 02:16 PM
  #33
cgm12mgc's Avatar
cgm12mgc
Thanks Peter. Tried searching but it's somewhat of a pain scrolling around through a million posts on my iphone
Old Aug 16, 2010 | 07:54 AM
  #34
Eric D's Avatar
Eric D
As stated in the earlier post by Peter,
For mounting the flex couplings use the following bolts.
Part # 12456213 = Torx M10 x 47 mm
Part # 88894027 = Torx M12 x 52 mm
Old Aug 16, 2010 | 11:23 AM
  #35
cgm12mgc's Avatar
cgm12mgc
good stuff! thanks guys, all parts on order now i play the waiting game....
Old Aug 18, 2010 | 05:07 AM
  #36
LT70ZR91's Avatar
LT70ZR91
While you are waiting for parts take a good look at your CV joints in the half shafts. We are doing a clutch and coupler job right now and when we went to put everything back together we could not get the upper control arms in place. It appeared that the half shaft was too long, and since we were pretty sure it hadn't grown, we pulled it out and found that the ***** in the CV joint were loose and rolling around inside. I am sure they were getting added abuse from the coupler failure. Our bolts did not bread and the car could be driven although it did have plenty of slop and knocking. We thought we would be done today but now are looking for a half shaft.
Old Aug 18, 2010 | 09:29 AM
  #37
Pumba's Avatar
Pumba
If you want to avoid another driveshaft - coupler disaster, you need to install one of these Pfadt Racing carbon-fiber driveshafts:
I know where one is for sale at a significant discount.
