Horn not working
Old 11-02-2010, 12:32 AM
frontalot
frontalot's Avatar
Default Horn not working
I recently discovered that my horn does not work. I checked all the fuses and tried replacing the relay without success. I can hear the relay click when I press the horn, but no sound is made.
Does anyone have a suggestion on how to troubleshoot the problem?
Old 11-02-2010, 03:15 AM
DeeGee
DeeGee's Avatar
There have been many cases of problems with the horn membrane. With the airbag this is not for the faint-hearted
Take a look at this one:
http://forums.corvetteforum.com/c5-t...brane-fix.html
Old 11-02-2010, 10:54 AM
frontalot
frontalot's Avatar
Thanks for the link, but I do not think it is applicable in my case because the relay still clicks when the horn is pressed. Any other suggestions?
Old 11-02-2010, 11:47 AM
DeeGee
DeeGee's Avatar
Looks like you need to check the voltage at the horn next then
Old 11-02-2010, 01:09 PM
FirethornC5
FirethornC5's Avatar
Get a digital multimeter and check the DC volts at the horn harness underneath the right front bumper with someone pressing the horn inside the car. If your have 12V than you need a set of horns.
To Horn not working
Quick Reply: Horn not working
