driver side mirror has a poltergeist. help!!!
Old Dec 8, 2010 | 03:16 PM
Florida Mike's Avatar
Florida Mike
Originally Posted by Bill Curlee
I have a busted c5 mirror somewhere,,,, and I will see if I can find it and detail a fix.
Without actually having it in hand and actually seeining how its constructed, I would say that you can pop the mirror out, remove the motor assembly and see if you can see the feed back pots. If you can, a good spray with some plastic safe contact cleaner and moving the controls thru their full ranges might be enough to make it work again.
If you cant, you will have to do some careful detailed disassemblyand then clean the pots.
Bill
That would be great Bill if you can post a picture or something. If not, I wonder of some long medical style Q-tips could be used with some cleaning solution to reach in if you pushed the mirror to each extreme? Or is where needs cleaned oin the back side of the assembly?
Forgive my ignorance, just never had the mirror out or one of them apart.
Old Dec 8, 2010 | 03:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NA,, from what I remember, the whole thing is in a plastic case assy and may need to come apart to get to the electronics.
BC
