Door lock working in one direction
Personally I wish I could find a relay that had even higher contact ratings like 20A for example. DC current (the arcing) can be brutal on relay contacts, especially with inductive loads like a door solenoid and a 20 amp version would last longer I'm sure due to it's higher contact rating.
Oh well, it is what it is.
After much looking at data sheets, etc, I came across:
NEC (brand) part # EQ1-31000S. The contacts are rated at 30A at 16VDC, compared to only 15A on the factory OEM relays. The coil current draw is a bit higher at 1000mW (vs the Panasonic's 640 mW) but I think this would most likely not be a problem either and well within the design-range of the door switch contacts on the car door.
I checked out the physical packaging (L, W, and H), and the pin layout and they are, in my mind, so close as to warrant a further look-see. It is a sealed, SPDT, Form C relay, and the pin arrangement is identical to the Panasonic JSM1-12V-5 relay.
Mouser is almost out of them (only 9,433 on hand
) so I think I'll order a couple to check them out. They're for cheap at $1.68 each. These are current production, so I think a good many other suppliers will carry them as well, especially since NEC is a well-regarded Japanese electronics company and makes a wide variety of other products.Just wanted to share this with everyone who likes to save a buck and doesn't mind doing a little desoldering and resoldering every once in awhile. If these pan out, they may solve the problem permanently instead of just replacing the relays with another identical piece, only to have them eventually fail too.
Glad you mentioned that.
Went back and double checked and guess what? Mouser's online data summary is wrong.
Mouser publishes data "summaries", or abstracts, for a great many of it's products in their catalog and online (where I have been looking) and they list the coil power consumption as 1000mW, but when I looked at the actual pdf data sheet published by NEC, it shows 640mW. Strangely, Mouser's actual catalog listing is correct.
Just to verify, I went to another electronics suppliers webpage and checked there too. Sure enough, the NEC data sheet they show is the same (640mW). Just to cross-check even further, I verified that the NEC coil resistance is the same 225 ohms as the OEM Panasonic 15A relay, so that proves that the coil power has to be the same, given the same voltage. That is unless DC circuit Ohm's Law has changed since last I looked.
Anyway, thanks for mentioning that.
Btw, while I was checking again, I came across a Panasonic relay that is designed to be a smaller version of the JSM that we have in our door modules. It is the "JJM" series (also a 640 mW coil) and occupies a little less real estate but coincidentally, is available in a higher contact rating of 20A (the JSM series maxes out at 15A) Apparently the NEC's EQ series is designed to compete with Panasonic's JJM series and be smaller but yet offer 30A max.
So, it seems there are two good alternatives here:
Panasonic JJM1-12V (smaller package and identical pin-out) @ 20A
or
NEC EQ1-31000S (smaller package and identical pin-out) @ 30A.
Guess which one I'm inclined to use?
Not sure when Panasonic and NEC introduced these slightly smaller series relays, but it's possible that it was after '97 which was when the first C5s started rolling out. Usually the parts suppliers have to get testing/approval from GM well before production begins and that's why (possibly) the earlier (JSM) versions were used and this board was designed in '96. Bad part is (in retrospect), the JSMs only have 15A as the highest choice available. Cost is always an engineer's worst enemy too.
Hopefully I'm wrong....
'97-'99 LDCM 9352881
'97-'99 RDCM 9352891
'00-'04 LDCM 9389689 (Superseded by 10342159?)
'00-'04 RDCM 10435192 (Superseded by 10342160?)
Perhaps the door lock/unlock/window functions are the same and that explains why a RDCM will "work" in a LDCM position say, for example to test a door actuator or window motor, but there are obviously differences or there wouldn't be two different part numbers and prices.
Although it's possible, or even likely, that there have been GM part number supercessions to these, the fact remains that there are different numbers for right vs left.
Last edited by LoneStarFRC; Dec 19, 2010 at 09:26 PM. Reason: Correct part number error and add info
