Door lock working in one direction
'97-'99 LDCM 9352881
'97-'99 RDCM 9352891
'00-'04 LDCM 9389689 (Superseded by 10342159?)
'00-'04 RDCM 10435192 (Superseded by 10342160?)
Perhaps the door lock/unlock/window functions are the same and that explains why a RDCM will "work" in a LDCM position say, for example to test a door actuator or window motor, but there are obviously differences or there wouldn't be two different part numbers and prices.
Although it's possible, or even likely, that there have been GM part number supercessions to these, the fact remains that there are different numbers for right vs left.
Like I said before, I think the only thing that makes sense is that on certain parts of the real estate on the boards, the circuits are the same, and other sections or the parts of the overall circuitry that deals with other functions, they are different. The notion that GM did this to "jack the price up" is just silly.
You seem to be saying hey, they're both the same so therefore just buy either one for whichever side you need it for. It doesn't ,matter.
What I am saying is that these have two different part numbers for a reason, and logically it makes sense that the driver's side has more functions, if for no other reason than it can control the window on the passenger side and it can also control the outside rearview mirrors on both sides. If someone wants to check their door lock solenoid or window motor to be sure that they are not the problem, and by temporarily swapping sides for testing purposes allows that, then great.
But testing, and just disregarding the side specific part number is asking for trouble, or at least a headache when some function or other doesn't work.
As far as this $450 you mention, I have done even cursory searches and prices run from $30-40 to $100 for used and $250 -$400 for new. Regardless, the whole point of this thread is to be able to fix or repair these things WITHOUT buying new, so I don't understand why a new unit is even being considered here.
Btw, I found at least two sources that will rebuild your old unit (probably replace the relays and test it) and return it to you for prices in the $65 to $70 range. Crazy expensive, huh?
65 Roadster **** 78 Pace Car **** 02 Convert
Or, perhaps the "countless" business is an exaggeration?
Future Electronics Inc.
3255 Pay Sphere Circle
Chicago, IL
60674
They are a Canadian company but I think this must be their US distribution point. The phone number to their Canadian office is:
514 694 7710
They had hundreds available when I ordered them 6 months ago.
Good luck.....
Sometimes, in order to "help each other" and in the interest of the greater good, it may be necessary to "pick apart" someone's post.
Chicago, IL
60674
514 694 7710
Good luck.....
I hit the LOCK button on the remote or either door switches and the PASSENGER door lock does nothing......
I've been used to just reaching over and locking it by hand before exiting but it's becoming anoying and decided to go ahead and replace what i thought was a bad actuator on the passenger side.
Turns out it's still doing the same thing!!!
I popped the accordion's on both sides, reached under the A pillar and checked the connectors and they are perfect. The ground wire shows no problem either.
I opened the module inside the passenger door and inspected the board which looks flawless. Seems like it has a silicone coating from the factory to avoid moisture corrosion issues (clever).
I ordered several of the type 5 relays from digi-key and just replaced the suspect relay. Same problem ensues! Not sure I see this part of my issue listed by anyone else, but if I push the lock button repeatedly it does eventually engage and lock (locks 1 out of every 5 pushes). It was doing this previosly so I figured the relay was failing and only intermittent. Thoughts???
I checked the pillar connectors; even put it back together with some dielectric grease so that won't develop later. I ended up concluding I needed to do the fix posted here by KCvetteowner.
I'll post my result from this attempt.
