Door lock working in one direction
Old Mar 25, 2011 | 09:49 PM
  #61
Cratecruncher's Avatar
Cratecruncher
An actuator is just a coil of wire. It can't fail in only one lock direction. Did you check that both the relays are properly grounded when not energized? Even if you have voltage on one side the actuator won't fire if the other wire isn't grounded.
Old Mar 26, 2011 | 06:59 AM
  #62
BryanRexford's Avatar
BryanRexford
8th Gear
OK, I will check that. I don't have a diagram so to verify are both of the wires that come out of the top or black plug grounds?
Old Mar 26, 2011 | 09:51 AM
  #63
Cratecruncher
No diagram hugh? You know this shi* is on-line right? A relay is either "on" or "off". When the lock relays are off the contacts flow to chassis ground. When a human hits lock or unlock on the switch panel one or the other relay is "on" which throws the contacts over to positive battery voltage. Since the other relay is "off" or ground it makes a circuit.
Both wires to the actuator should have zero ohms resistance compared to a reference chassis ground when the lock switch is not being activated. When the lock switch is pushed one of the wires should show battery voltage. When the unlock is pushed the other wire should show battery voltage. The above test still doesn't rule out fried relay contacts but gets you closer to the problem.
The next step is to evaluate current draw. By measuring the current on a lock circuit that works you get a reference amperage. Then on the side that doesn't work test to see what you get. If there is a bad connection (or fried relay contact) the amperage will be considerably lower. There is not enough inductance to drive the actuator in that direction. If you want to figure out which relay is bad you can jump the "ground" actuator contact directly to ground. If the actuator begins working 100% its the ground on one of the relays. If the jumper doesn't help you know it's the other relay's energized contacts that are bad.
Bottom line however, if one contact is bad both relays should be replaced and I'd buy two additional relays for the other door to save on shipping. The main reason I shared the procedure above is to help rule out bad connections and other simple things. I hate wallet diagnostics - replacing parts ***** nilly hoping it will fix the problem.
Old Mar 28, 2011 | 08:07 AM
  #64
BryanRexford
8th Gear
And where online would these diagrams be found?
Well I changed the unlocking relay or atleast what I believe to be the unlocking relay according to the fix. Works like a charm now!
If anyone else reads this post with this issue and decides to try the fix suggested; just change both relays not just the one!
Thanks guys!
Old Mar 28, 2011 | 11:43 AM
  #65
Cratecruncher
Thanks guys!
Here you go. http://forums.corvetteforum.com/c5-t...al-on-dvd.html
Glad all is working for you now.
Old Mar 31, 2011 | 04:24 PM
  #66
redfin's Avatar
redfin
Cruising
Originally Posted by LoneStarFRC
I don't think there will be a permanent shortage necessarily. Check back with Mouser Electronics or Digi-Key from time-to-time. They are the two 800 lb gorillas of the electronic supply companies out there these days and as far as I can tell have them on back-order. You may want to check with some of the other smaller, independent, supply companies too.
Personally I wish I could find a relay that had even higher contact ratings like 20A for example. DC current (the arcing) can be brutal on relay contacts, especially with inductive loads like a door solenoid and a 20 amp version would last longer I'm sure due to it's higher contact rating.
Oh well, it is what it is.
If you still haven't ordered the relays by now, Digi-Key has 10,000 in stock. I ordered 4 today @ $1.68EA.
Old Jun 30, 2011 | 07:22 AM
  #67
UstaB-GS549's Avatar
UstaB-GS549
989 in stock at Allied Ellectronics. Use JSM1-12V for part number search.
PANASONIC ELECTRIC WORKS
Relay, Automotive, 15A, 12VDC, SPDT HI-Capacity, Sealed PCB
788-0523 JSM1-12V-5 $1.390 Each
I just ordered 4.
Replaced the passenger side locking realy only. It's the bottom one on the passenger side board. I used wicking and a 700 watt iron. You need to activate solder with flux or it will not wick out of the holes in PC board. My 25 watt pencil iron was insufficient for desoldering.
Old Sep 20, 2011 | 05:29 PM
  #68
jespo27's Avatar
jespo27
4th Gear
I'm trying to determine if I have same problem.
My drivers door lock works does not lock or unlock with fob. pass side works great. the interior lock/unlock control button has no effect on lock, though i can hear clicking. I have panel off and would like to test light the proper wire for voltage when i press fob. does this sound like a module relay problem? if i take door module out is there a test to see if it's bad? can pass side module be used to test drivers door?
Any help would be appreciated.
Old Sep 20, 2011 | 07:16 PM
  #69
BumbleZ's Avatar
BumbleZ
Default Sounds like the relay
That sounds exactly like the problem I had only mine was on both sides. I went ahead and desoldered and replaced the relays myself, which was an experience because the old relays are encapsulated in some kind of water proofing material and it was a B*&ch to get the old ones off.
I tried when my two door panels were off and the boards were not interchangeable on my 2002 Z06.
Good luck.
Old Sep 20, 2011 | 08:25 PM
  #70
white90conv's Avatar
white90conv
I had trouble loading the GM manual on my computer. At one time it worked but it uses some program that got messed up by another application. I spent quite a bit of time but never got it to work again. Fortunately, I have it on my laptop also. You have been warned - it may not load properly.
Old Sep 21, 2011 | 01:53 PM
  #71
jespo27's Avatar
jespo27
4th Gear
I am going to try to swap modules from pass to drivers.
Before I do that, I was thinking of putting 12v from battery with a 5 amp inline fuse to see if the actuator works. Can I just touch those leads to where harness disconnects to pins in actuator to rule out actuator problem? I don't want to fry anything. Is there an easier way to rule out actuator?
Old Sep 21, 2011 | 02:39 PM
  #72
jespo27's Avatar
jespo27
4th Gear
As far as door module goes, I know the 2 bottom ones are for lock and unlock. Is the third one for window ?
would any of those relays cause an erratic drivers power mirror upon pressing the "memory 1" button?
Old Jun 17, 2013 | 09:27 AM
  #73
GMJim's Avatar
GMJim
Interesting thread! Surprised it isn't a sticky? Anyway this is a great fix for an otherwise very expensive part. I put a test light on the leads from the module to the actuator and got a signal that both lock and unlock power was being sent to the actuator. Therefore determined that the actuator was at fault. So i bought an actuator from GM for the drivers side and installed it. Same problem? (seems you can buy just the actuator for the passenger side in the aftermarket but can't for the drivers side. You must buy the whole latch assembly for the drivers side)?
Anyway if you test for output power from the module and get it, it doesn't mean you're getting the amperage. I guess this is why the dealer wants to change both of these items at the same time? I'm gonna try the relays and see what happens.
Old Jun 17, 2013 | 09:39 AM
  #74
BryanRexford
8th Gear
Relays fixed mine. I bought extras from digi-key for when the drivers side goes.
Old Jun 19, 2013 | 08:55 PM
  #75
zet06's Avatar
zet06
U can get them direct from Digi Key in Thief River Falls MN 56701-0677 . Its pn 255-1240 -ND Shipped fed ex to your home cheap
and then take to an audio repair place and they can do ,
my 2 DCMs cost me 25 bucks for the labour and 25 bucks for the relays delivered.
one of the funniest things after repair was that when I take the key out of the ignition it unlocks the doors , never before
Old Jun 26, 2013 | 12:10 PM
  #76
GMJim's Avatar
GMJim
Replaced both relays and it's fixed! Thanks to the pioneers that dug into this issue. $4.00 worth of relays and an hour of my time is much cheaper than $400.00 plus for a new module!
Thanks.
Old Aug 18, 2013 | 10:01 AM
  #77
kupperjo's Avatar
kupperjo
4th Gear
Default Door actuator relays
I replaced the close relay per the instructions and the passenger door will now unlock.
Thanks to all for the information.
John Kupper
Port Neches, Tx.
2001 Vette owner
To Door lock working in one direction
Old Sep 11, 2013 | 03:14 PM
  #78
SKF engineer's Avatar
SKF engineer
The "ronjpics" site is down. Does anyone have another location where I can find the procedure to get at these modules.
Old Sep 12, 2013 | 04:34 AM
  #79
ZeeOSix's Avatar
ZeeOSix
I happened to have this in my archives. I wonder if anyone has done a YouTube video showing the fix? ... I haven't checked yet.
http://www.valleyvettes.ca/door_module.html
Old Mar 25, 2024 | 04:50 PM
  #80
ijakie1's Avatar
ijakie1
Hey, listen up there Sparky, I never said these things won't interchange and at least some of the functions will work or that you will "HURT THE MODULE", YOU did. You seem to be saying hey, they're both the same so therefore just buy either one for whichever side you need it for. It doesn't ,matter.
What I am saying is that these have two different part numbers for a reason, and logically it makes sense that the driver's side has more functions, if for no other reason than it can control the window on the passenger side and it can also control the outside rearview mirrors on both sides. If someone wants to check their door lock solenoid or window motor to be sure that they are not the problem, and by temporarily swapping sides for testing purposes allows that, then great.
But testing, and just disregarding the side specific part number is asking for trouble, or at least a headache when some function or other doesn't work.
As far as this $450 you mention, I have done even cursory searches and prices run from $30-40 to $100 for used and $250 -$400 for new. Regardless, the whole point of this thread is to be able to fix or repair these things WITHOUT buying new, so I don't understand why a new unit is even being considered here.
Btw, I found at least two sources that will rebuild your old unit (probably replace the relays and test it) and return it to you for prices in the $65 to $70 range. Crazy expensive, huh?
BTW, IT WOULD BE GRATELY VALUED IF UR (2) RESOUCES CAN BE HAD. I BELONG TO A SMALL TOWN VETTE CLUB IN DEEP EAST TX & I DO WORK ON C4 & NOW QUITE A FEW C5's. HELP.
