Suspension advice needed!
I would like some advice for the best scenario for my car. I will not track the car on a road coarse, but really enjoy spirited driving. I want the car to be up to date, feeling good and tight, still handling well. I really enjoy the performance aspects of my car. A friend of mine suggested the car could have not enough sway causing it to easily skid. So, nothing to nasty, just time to do some up grading.
Considered choices
-keep existing bars and upgrade to medal end links
-C6 Z51 sway bars and end links
-C3 Z06 sway bars and end links
- Either of the C6 options w/ medal end links
Thank you for your time and input!
Rob Edwards
If you want a bit more you can upgrade to a C6 ZR1 front bar and a C6 Z51 rear bar.
Here is a chart with the relative stiffness of the bars..
http://forums.corvetteforum.com/auto...of-pfadts.html
What you want to do is make sure you match the stiffness so that your car remains balanced. If you put too big a bar on the back the car will oversteer and if you put too big a bar on the front it will push like a pig.
You will note that on your car the front bar is stiffer than the rear bar, and that is by design since you don't have huge tires on the back like a ZR1.
So what you want to do is select a set of bars that will give you more stiffness in the front than in the rear. Note that you can upgrade to a set of C5 Z06 bars and that will maintain that relationship. So will the ZR1 front bar and the C6Z51 rear bar. You will need the bushings for each bar and you also need to make sure that the C6 bar will fit on the back of your car. I'm not sure about that. Also you can talk to ADDCO, their bars are relatively inexpensive and explain that you want something that is balanced and they will be able to set you up.
Hope this helps.
Hope this helps.
Thanks a lot, very helpful. My tire and wheel sizes may make a difference. Fronts-275/35/18 CCW'S
Rear -295/35/19
Let us know what you choose and how it turns out.
BC
