balancer replacement questions
Old Jan 13, 2011 | 02:12 PM
Cratecruncher's Avatar
Cratecruncher
Gawd, now I'm really getting worried! My HB is a bit wobbly at idle and the (new) belt chirps some at higher rpm. I took the belt off and the ring "felt" solid but considering the forces involved that's probably not worth much. Chirp goes away with a drop of armorall so pulleys are ok. Bolt is tight. Am I on borrowed time?
Old Jan 13, 2011 | 03:03 PM
mcm95403's Avatar
mcm95403
I think I'm going to just do this as a pre-emptive strike regardless of parts appearing to be bad or not. Too many horror stories and I'd rather fix it before I get stuck or break something more expensive.
Thanks for all the input guys!
Old Jan 13, 2011 | 04:12 PM
guido7834's Avatar
guido7834
Originally Posted by Paul Wood
And to your other question! Your warning sign IS the wobbling. I would replace it soon.
How much wobble are you talking about? Mine is so slight at idle but as soon as the revs go up there is none at all.
Old Jan 14, 2011 | 06:40 AM
FiberglassFan's Avatar
FiberglassFan
Originally Posted by Chevy Guy
Don't take everything you read here as gospel. The rubber pulley ring going bad and causing a wobble isn't really going to "cause a lot of damage", slipping on the crank will. I've been wrenching a long time and NEVER seen an OEM balancer on an unmodified car fail. If you are doing some work that necessitates a balancer removal, by all means replace it with a new one.
That being said - a pinned under driven pulley is a nice mod.
One did on my car...at about the mid 120K miles....Ok, not REALLY modifed,,,just a high flow air filter and bridge, a ZO-6 catback and a nice tune...otherwise stock cam, heads, TB, cast headers, etc...the the pulley DID indeed fail..the rubber was a mess...
Old Jan 14, 2011 | 06:46 AM
FiberglassFan
One did on my car...at about the mid 120K miles....Ok, not REALLY modified,,,just a high flow air filter and bridge, a ZO-6 catback and a nice tune...otherwise stock cam, heads, TB, cast headers, etc...the stock pulley DID indeed fail..the rubber was a mess...I had it replaced with another stock unit.
Old Jan 14, 2011 | 08:47 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FYI - The possibility of the balancer "seperating" is not the main concern. I have never seen a LS1 balancer seperate. The main issue is that the balancer can slip on the crank snout, causing damage to the crank itself. Whatever balancer you choose, it would be a good idea to pin it.
FWIW, the late LT1 'balancers' ('92-'97) were simply a 'press fit' on the crank snout also.
Old Jan 14, 2011 | 12:48 PM
Cratecruncher
My OEM H.B. is about to let go and I plan to do the job myself.
1) I'd like to pin the crank but I'm going to use the Powerbond OEM replacement (PB1117N). None of the OEM style HB's have a keyway right?
2) If the Balancer is an interference fit how hot should the hub be during removal/replacement. I've heard 150-200F will persuade them off/on in other threads.
3) I know I'll need 24mm socket to remove/replace H.B. bolt. But nowhere have I seen anyone mention the thread size for the fastener. Anyone know? I'd like to use all-thread and a nut to press the new H.B. on to insure I don't overstress the crank threads.
Old Jan 14, 2011 | 02:34 PM
leadfoot4's Avatar
leadfoot4
I can't help you with the thread pitch/diameter, but if you can determine it, let me make a suggestion. Instead of the all thread bolt, obtain a 6-7" log piece of threaded rod, and lock 2 hex nuts together on one end. Then thread another hex nut about half way up the rod, followed by a few flat washers.
Get the balancer loosely in place, thread the rod into the crank snout, use the locked hex nuts to hold the rod, and with a second wrench, turn the single nut and washers, and use them to press the damper in place.
That's a 'poor boy' damper installer....Works every time!
Old Jan 14, 2011 | 04:52 PM
vettenuts's Avatar
vettenuts
See below for answers. I made this tool with 300mm threaded rod and some nuts & washers. Have used it numerous times and it works like a charm. During removal, don't follow Ls1howto.com, recipe for disaster and don't use the old bolt to push on for removal, use a socket or something the will apply the force to the end of the crank, not the threads.
ATI does, and if pinning the Powerbond you will need the ATI pinning kit.
I would not heat it, this is just a poor work around for not having proper tools.
M16X2mm
Old Jan 14, 2011 | 06:56 PM
Cratecruncher
Thanks for the info guys. It's exactly what I needed. I've been running around town gathering stuff up for this project. I'll visit our local fastener specialists on Monday and ask them to build up a "poorboy" for me!
Old Jan 15, 2011 | 09:51 AM
leadfoot4's Avatar
leadfoot4
Originally Posted by vettenuts
You infringed on my "poor boy balancer installer" patents!!!!!
Old Jan 15, 2011 | 02:41 PM
Cratecruncher
I purchased a front timing cover/crank seal when I bought my new H.B. bolt at the dealer. Mine doesn't leak but I figured while I'm in there.... Is it possible to r&r the seal without removing the timing cover & water pump from the engine?
Old Jan 15, 2011 | 03:02 PM
  #33
lucky131969's Avatar
lucky131969
Sure. Look in your service manual under "Crankshaft Front Cover Oil Seal Replacement".
Old Jan 28, 2011 | 06:42 PM
  #34
Cratecruncher
I started replacing my harmonic balancer this morning. I got my steering rack out of the way with only moderate use of profanity and have the p/s and water pumps off. Now onto the H/B.
Since my car is a '99 M6 I was under the impression from reading at least a dozen DIY threads here and on other websites that all I have to do is put the car in 6th gear, chock the wheels and start pulling. Well after doing that it feels like I'm pulling on a rubber band. No way will I ever get 240 lb-ft of torque delivered to that bolt! Not only that but I could hear the springs in my pressure plate groan and twang as well. Now my car is taken apart and I'm stopped dead. In all those DIY threads did I miss something???? I'm currently trying to jury-rig a strap wrench with a belt and pipe to fit around the H/B. Every strap wrench available locally only fits up to 5" dia and the H/B is 7.5". Are there any other work-arounds? Has anyone tried restraining the flywheel without the special GM tool? Has anyone even run into this problem or is my car just "special".
Old Jan 28, 2011 | 07:34 PM
  #35
ipuig's Avatar
ipuig
St. Jude Donor '09
If you are using the OEM TTY fastener, that torque spec is not correct. You will never get it tight enough without locking the flywheel as the service manual directs.
So much for the web based DIY instructions.
Old Jan 29, 2011 | 08:51 AM
  #36
vettenuts's Avatar
vettenuts
If you are removing, there is a lot of windup in the drive train when you start pulling that bolt. You need to set your wrench low enough to be able to overcome the windup and loosen the bolt. If you can't, then get the correct flywheel lock to hold the flywheel in position.
Old Jan 29, 2011 | 12:25 PM
  #37
Cratecruncher
Wow, I have a unique drivetrain and now you tell me I have a unique one-of-a-kind Factory Service Manual too! Page 6-9, "Crankshaft Balancer Bolt "Installation Pass-to Ensure the Balancer is Completely Installed." 240 lb ft. I'm going to put that baby on eBay as a collectors item! (Ipuig, I'm just bustin' your chops for correcting me. I agree with the rest of your comment.)
Yes Vettenuts. I concluded yesterday that attempting to use the drivetrain as an engine lock is just plain insane.
Even if I were to get the original bolt loosened without progressive drivetrain damage there is no way to seat the new balancer or torque the new bolt accurately. While a modified strap wrench would likely work I don't have a helper or the muscle to hold both at the same time. A flywheel lock was ordered yesterday. I'll likely use it once and resell it on eBay. Lesson learned: moving on.....
To balancer replacement questions
Old Jan 29, 2011 | 01:00 PM
  #38
Cloaked323's Avatar
Cloaked323
I hear ATI is the hot setup it's used in NASCAR as well as other professional race car application with that said if engineers and crew chiefs use them on their professional race engines I would use it on mine.
Old Jan 29, 2011 | 08:30 PM
  #39
ipuig's Avatar
ipuig
St. Jude Donor '09
If in fact you have the OEM service manual, you should read a little further along in the procedure. 240 ft/lbs is the initail torque value used to ensure the balancer is fully seated on the crank-shaft snout.
Old Jan 29, 2011 | 09:49 PM
  #40
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
All you needed was a fly wheel tuner. Hard to explain what it looks like. Kinda like a big screw driver with a steel half moon loop. Since you've already ordered a special tool it's not much help.
Back in the day I used to spin HB's on 454's all the time. I'll agree GM could use a higher quality manufacturer. Trust me, I've been involved with supplying some of the major vendors to GM with raw product, and what we ship falls short on quality. Then again it's not just a GM issue.
