air tubes
Old Jan 15, 2011 | 05:10 PM
littleed's Avatar
littleed
Default air tubes
any know where i can buy the blockin plates for them and will it throw a code still?
Old Jan 15, 2011 | 05:37 PM
lucky131969's Avatar
lucky131969
Yes, the codes will continue until tuned out.
http://www.ls1speed.com/cont.cfm?cid=C0000045
Old Jan 15, 2011 | 07:29 PM
vettenuts's Avatar
vettenuts
If you have headers, it is recommended you cut the tube off and not use the block off plate. The use of the block off plate typically results in eventual breakage of the tube.
Old Jan 15, 2011 | 07:49 PM
littleed's Avatar
littleed
wont it still blow out air then? sorry if i sound like an idiot i do have headers installed i plan onm getting the air tubes tunes out just not sure wta to do with the air tubes so u cut of the hose then wat?
Old Jan 15, 2011 | 07:54 PM
lucky131969
all yours Vettenuts......I can't deal with these Iphone responses.....
Old Jan 16, 2011 | 12:57 AM
littleed's Avatar
littleed
i phone om in iraq no cellphones here im just a really bad typer sorry for the bad spelling just trying to get everythin together so when i get home i can get started
Old Jan 16, 2011 | 09:13 AM
bmfvette's Avatar
bmfvette
I guess everyone has their own opinion on this. I have LG Pro's and blocked them off cause I didn't want to weld on the pipe. I had a local custom radiator shop stamp out the plates. They even enscribed a chevy bowtie with the initials "BMF" in the middle of the bowtie on them. I used the original gaskets and stainless steel dome top hex head bolts to attach. No issues.
To air tubes
