power steering leak, pics inside
Old Jan 29, 2011 | 06:19 PM
Ghost Friend's Avatar
Ghost Friend
Default power steering leak, pics inside
So I noticed a little pool of fluid on the garage floor. After crawling under the car, it's coming from the power steering lines, specifically the rubber line that runs from the reservoir then to a hard line and into the PS cooler. It also looks wet on the hoses that are coming out of the cooler, but I think it may be dripping from the hose above. Pics are below.
So what are my options here? I've searched about 7 pages of power steering threads, most of which refer to leaks at the rack. One made reference to having to replace the cooler assembly, but I couldn't discern if that was the only option. If I can fix without buying the whole cooler, I'd obviously prefer that method.
I'm sure I'm not the first person to experience this, so what'd you do to fix?
Old Jan 29, 2011 | 08:31 PM
tom01ss's Avatar
0tom01ss
Former Vendor
new lines and clamps
Old Jan 29, 2011 | 09:06 PM
Ghost Friend
just the rubber lines? any idea on inner / outer diameter? I realize I could take it apart and take the pieces with me, but if I have it ahead of time, it'd just be easier to disassemble / reassemble at once.
What type of clamps are those?
Old Jan 30, 2011 | 12:03 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If it were me,, I would just cut the crimp bands and purchase some gates hose clamps and install those. What have you got to loose? Either that or new GM Lines.
BC
Old Jan 30, 2011 | 02:20 PM
Ghost Friend
BC
That sounds like a plan, it's worth a shot. It looks like the smallest gates clamps they sell are 1/2" to 11/16" OD, do you think those would fit?
If that doesn't work, do you know if the GM lines are just the pre-cut rubber pieces or does it include the hard lines? any idea what the actual part name is? I'm having a hard time finding the actual lines I'm looking for when I search.
Is it possible to buy generic rubber lines and cut them to length?
Old Jan 30, 2011 | 04:38 PM
robert miller's Avatar
robert miller
You are lucky man. If these clamps start leaking replace them they are junk....
To power steering leak, pics inside
