Hurst Shifter
Old Feb 8, 2011 | 10:28 AM
marco383's Avatar
marco383
Default Hurst Shifter
My Hurst shifter (C5) is a high effort affair. I recall something about removing one of the springs to remedy this; am I dreaming?
Old Feb 8, 2011 | 11:01 AM
hotwheels57's Avatar
hotwheels57
If you bought the shifter new, it should have come with different sets of spring combinations allowing for very firm to easier shifting efforts.
If you bought the shifter used, evidently you didn't get the other spring sets. I'm not sure you can remove just one spring and get reliable performance. I could be wrong.
You might contact HURST/B&M to see if the springs are available ala carte or if you can remove just one spring w/o any issues. Otherwise, you have to live with it, experiment with hardware store springs, or find another shifter.
Old Feb 8, 2011 | 12:06 PM
vettenuts's Avatar
vettenuts
I tried that and found that the lighter springs, which also hold the shift lever down in place, didn't help much. In the end, I removed the shifter.
Old Feb 8, 2011 | 02:19 PM
johnson-rod's Avatar
johnson-rod
Have you tried backing out the two adjustment screws on the top of the shifter? These two screws (allen head) adjust how hard the springs are pressed down. Try backing them out a little at a time until you are satisfied with the feel. Use locktite (blue) to hold them in place.
Be sure everything is adjusted and lubed nicely. That makes a big difference in shifter feel.
Old Feb 8, 2011 | 07:03 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I used the lighter springs and love the Hurst.
Old Feb 8, 2011 | 08:22 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I left the hurst oem springs in and just put miles on it. it loosens up the more you use the car Love the hurst!
To Hurst Shifter
