Yeah, I saw that. Mine gets about 26 at 80 w/4:10's and 6 speed. Maybe he has headers which can give better mileage and a good tune. Runflats also give better mileage than my non runflat GSD3's.
What about when you have a cammed car? I have a Torquer V2 and of course the headers and all the other bolt ons that go along with a cammed car. I know you have to try to match the gears with the power band of the cam for best results. Are the 4:10 too much or would 3:73 or a 3:90 be better?
Not rying to hijack, just didnt want to start a seperate 4:10 thread.
I had my car at 155mph a few dozen times . But this is not my main driving style. I will be willin to trade off, but was curious. Do you have a seat of your pants feel with these gears?
What about the cam though? Car seems a little boggy sometimes doing a 3-4 shift. I dont care about top speed, I do want the crisp throttle response that I know is there.
4th gear - depending on your tire and driving abilities, you will have to raise your limiter or get a taller tire.
On a cool day in November of 2009, I went to a track rental. My first run I hit the limiter that was set at 6400. I had my tuner raise it to 6600. No more problem.
I was using 25.7" tall Hoosier drag radials and trapping 119 - 120.
Yup, lighter wheels than stock, lowered, toyos with about 34 lbs of air, headers, and great tune! oh and not to heavy on the pedal to get to 80
You have to kinda work to get that with 3:42's; I'm doubting thats the 4:10's are still getting that good of mileage. Also, I'm pretty sure theres some tuning work with regard to tuning for the MPG to be accurate when gears, injectors, FI or a cam has been installed. Otherwise the PCM still uses the tables for stock gears, injectors ect; I've seen this somewhere else in the scan and tune section I believe.
