do you run 4.10 gears?
Old Feb 13, 2011 | 06:09 PM
  #41
bumble-z's Avatar
bumble-z
Originally Posted by Ole Blaster
anyone know the cost to have 4.10 installed??? estimated labor cost??cause I would love to have done!!!
With not having your profile filled out, it would be hard to recomend a shop in your area when there is no mention of where you live, what you drive, tranny, year, mods etc.
Old Feb 13, 2011 | 06:28 PM
  #42
Ole Blaster's Avatar
Ole Blaster
Yep I still havent done that... (SORRY) 1999 FRC 6 spd Wilmington NC And I'll work on the profile... Thanx!!!
Old Feb 13, 2011 | 10:08 PM
  #43
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
You can get it done for $2500 - likely a lot less.
Old Feb 13, 2011 | 10:52 PM
  #44
evo2ls1's Avatar
evo2ls1
Originally Posted by Millenium Z06
You have to kinda work to get that with 3:42's; I'm doubting thats the 4:10's are still getting that good of mileage. Also, I'm pretty sure theres some tuning work with regard to tuning for the MPG to be accurate when gears, injectors, FI or a cam has been installed. Otherwise the PCM still uses the tables for stock gears, injectors ect; I've seen this somewhere else in the scan and tune section I believe.
You guys must drive like there is somebody chasing you everywhere you go lol, I definitely got that and better with my 3.42's. I will check it the old fashioned way with paper and pen and see what I get.
Old Feb 14, 2011 | 01:20 AM
  #45
f6john's Avatar
f6john
I have not been in 30 mpg territory yet but I've only had the car for 6 weeks. But the 700 mile return trip only netted about 28 mpg with the 3:42's and 90% of the trip was spent in 6th. After reading your post the only conclusion I could come to was that I have been driving too slow.
Old Feb 14, 2011 | 11:31 AM
  #46
craig04c5's Avatar
craig04c5
Actually to get 30+ you need to keep the speed under 75 and on the hwy. I got 33 behind a 16 wheeler on a flat Rt 95 from Florida to NC when I had my 3:42's and runflat tires.
Old Feb 14, 2011 | 07:58 PM
  #47
Ole Blaster
wow thats alot of cash!!!! Well I guess I'll stick to the 3.42 for a good while ( I just dumped a grand in the starter and 2 sensors replaced) and that hurt..... thanks for the time and info Sir...
Old Feb 14, 2011 | 10:17 PM
  #48
mcm95403's Avatar
mcm95403
Corvette Central has the diffs ready to go for $1295.
Old Feb 14, 2011 | 11:06 PM
  #49
C5 Pete's Avatar
C5 Pete
AMP Racing
I was giving a price including install.
If you can do the work yourself or have friends that can help, you'll save a lot of money.
Old Feb 15, 2011 | 12:50 AM
  #50
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Does that price include hardend axles ?
some of these mods get pricey when you factor in the labor. If you have an auto tranny and change gears you need to get your tranny shift points reset.
Old Feb 15, 2011 | 04:43 AM
  #51
rootpooty's Avatar
rootpooty
Its not 2500 i live right by DTE inc they are one of the main dingos that specialize in corvette driveline in the country and the install starts at 1395 and for a really good install with better output shafts and the whole kit and kaboodle its around 1995
figure in a shop is going to charge around 500 labor for the swap then you need your speedo recalibrated
Old Feb 15, 2011 | 04:33 PM
  #52
Ole Blaster
got it,,I will check a place here for a quote,, I heard this was the place for gears and tranny work,,,,thanx a bunch....
Old Feb 18, 2011 | 10:20 PM
  #53
Millenium Z06's Avatar
Millenium Z06
Moderator
I can easily get into the 30's as long as I'm under 80. 80-85 is about 25-7 mpg
Old Feb 19, 2011 | 01:07 AM
  #54
f6john's Avatar
f6john
You got 4:10's?
Old Feb 19, 2011 | 06:55 AM
  #55
JanCorvette's Avatar
JanCorvette
What about just changing your ring and pinion for a motive gear 4.10? They are just 300 bucks. Is it very complicate? I have heard that they my whine a bit. Any experience?
Old Feb 19, 2011 | 08:11 AM
  #56
87gtNOS's Avatar
87gtNOS
I think that for the expense of the actual whole job, it is just easier to buy the whole pumkin with the gears in it already.....someone correct me if I am wrong because I have a buddy who owns a Mister Transmission that said he would do the swap for me....but if it's easy to put the gears in the pumkin and save $1000, I'm in!
On the other hand, when you buy the pumkin, you get the hardened output shaft, etc...
Old Feb 19, 2011 | 10:03 AM
  #57
JanCorvette
Well I lived in the dominican republic where labor is dirt cheap.
I can get the ring and pinion change for $150-200 bucks at my shop. And is a good shop too...with over a few dozen 9 and 10 seconds supras, rx7s, evos, mr2s. Will change they out in a jiffy
To do you run 4.10 gears?
Old Feb 19, 2011 | 10:12 AM
  #58
nyg215's Avatar
nyg215
if you are going to swap out just the gears and not the whole dif make sure you buy some hardened output shafts!!! they are a must if you plan on taking the car to the track
Old May 30, 2011 | 04:23 PM
  #59
JanCorvette
Do 4.10 and 125 Shot mix? Is it a bit much?
Old May 30, 2011 | 09:17 PM
  #60
vjjack04's Avatar
vjjack04
Folks,
I haven't read all the post but, I have DTE 4.10 rear diff. It was under $2k and easy to install at home in my garage. However, I believe on the street it is a bit steep. When on the gas (I have a built LS3) I shift into second within, like 12 feet of launching the car from first.....this is on street tires though......
