Out of curiosity, why not? I love the feeling of the 4:10s
The Z06 has different transmission gearing and 4:10's would make you shift out of 1st pretty quickly. My coupe with 4:10's requires you to shift at 30 mph at redline and 48 in second.
What tires are you running and what is your redline? My MN12 with 4.10s and short 315/30r18 tires 1st is good for 42mph and 2nd 61mph with a 6800rpm limiter.
Prob because he is still running factory limiter which is 6000. Still you reving 800rpm more doesn't equate to the mph difference.
That is correct. I have read that raising the rev limiter does not equate to more performance on a stock engine like mine. As a matter of fact 5800 is the peak for stock so no point in pushing it past that unless you are doing the 1/4 mile and trying to avoid another gear shift. I run stock size non runflat tires.
Exactly as I run a 1" shorter tire than stock and shorter trans gearing. At 6000 on stock size tires, MN6 trans and 4.10s it equates to 44mph in 1st and 65mph in 2nd.
