shock simulators
Old Feb 26, 2011 | 08:40 PM
riverrat68's Avatar
riverrat68
Default shock simulators
I put the simulators on. swapped out the shocks for bilstien sports. the "don't exceed 80 mph" has come back on.......any ideas ?? Do I still have to take it to a tuner?
Old Feb 26, 2011 | 11:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you have F-45 or F-55 suspension?
What DTCs are you displaying?????
A TUNER can do NOTHING for you UNLESS he has a GM Tech2. The RTD information/RPO codes lives in the BCM. The only thing that can change BCM programming is a Tech II.
Read your DTCs.. and post the DTCs...
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Feb 28, 2011 | 08:40 PM
riverrat68's Avatar
riverrat68
Bill
I am printing this off asap. I will take to a more smarter guy than I. I cannot thank you enough for all you help. I know if I had to do it again, I think I would just put the correct shocks on. I will let you know how it turns out. I have swapped the shocks to the Bilstiens and added the simulators. The local Chevy dealer gave it a whirl and nothing.
Thank you again.
Jerry
Old Mar 1, 2011 | 02:51 AM
HawnHog's Avatar
HawnHog
or.... you could return the simulators and try this. It works!!
Here is a simple fix to your query. (Found it in the C5/C6 Solutions in the C5 Corvette Forum.) I replaced the shocks on my '98 C5 with a set of Sport Bilsteins and this solution WORKS! Another alternative is to replace the shocks then go to a GM dealer and have them plug into your computer and turn the F45 shock feature off. (Easy, but costly.....)
Go to Radio Shack and get the following:
4 Resistors
#271-132
10 watt 10 ohm
(The resistor is a 2 inch X 1/4 inch ceramic block with a solid silver wire on each end. Two in a pack so buy two packs.)
Underneath the car at each shock location there is a black wire running from the shock to a blue connector. The wire does not unhook at the shock but if you trace the wire you will find the connector. Disconnect the blue connector from its mate and remove the shock.
Take a pair of wire cutters and cut the wire as close to the shock as possible. You will be left with the cut wire on one end and the blue connector at the other. Remove about three inches from the black insulation to expose the two wires (black & white) that it conceals. Strip both of them back about an inch.
Insert the resistor into a rubber hose (w/the wires protruding from each end) to protect it; solder the resistor between the two bare wires (black & white) that originally went to the factory shock to complete the circuit. I used some water proof silicone to seal the solder and wrapped everything in electrical tape. Reconnect the blue connector. Tuck the package out of the way and secure with zip ties. This will fool the computer into thinking the F45 Shocks are still there (as the computer looks for its resistance). Install the replacement shock.
Repeat for all four corners and you will be good to go.
Old Mar 1, 2011 | 01:24 PM
Bluefire's Avatar
Bluefire
Originally Posted by 8VETTE7
From the OP's profile he has an 04. The F45 option was NOT available after model year 2002. So if his car has the upgraded ride control option it had to be the F55 RPO.
The F55 RPO is very differnt than the F45 RPO. NEITHER Simulators nor Resistors work for deleting the F55 option.
Here's the procedure for deleting the F55 option from a post I copied a while back. It requires use of a TECH II AND must be followed EXACTLY.
1. Hook up your Tech 2 (Driver's footwell), turn the car ON, make sure the module in the left rear storage compartment (pull back the velcro lining on the front of the compartment) is plugged in. DO NOT UNPLUG THIS MODULE
2. Now use the Tech 2 to delete the F45 option ( F55 option does not appear on the Tech 2 menu screen - SO - DELETE THE F45 OPTION
(use the screen captures - steps 2-14)
3. Save the new configuration
4. DO NOT TURN THE CAR OFF DO NOT REMOVE THE TECH 2 Go to the module in the rear of the car, unplug the GRAY connector - IT IS THE WIDEST ONE - leave the other 1 (F/45) or 2 (F/55) plugged in.
5. Turn off the car but LEAVE THE TECH 2 PLUGGED IN
6. Remove remaining plugs from module in the rear of the car - Never plug them back in again, if you do the F/45 turns on automatically.
7. Now the moment of TRUTH - Turn the car on and verify that the dreaded - MAX SPEED 80 MPH - is gone. This message was only present if you had already disconnected the shock sensors. Some people have had to disconnect their battery to allow the computer to reset to remove this message, but I would confirm with the Tech II that the F/45 was actually deleted first and if not reconnect everything and start again with step 1.
8. Unplug the Tech 2 - Get in the car and take it for a ride. Smile as you pass the DREADED 80 MPH.
I just installed Pfadt coilovers a week ago. This is the correct procedure that my tuner used also.
Old Mar 3, 2011 | 01:37 AM
HawnHog's Avatar
HawnHog
Learn something new here everyday - MAHALO!!!
Old Mar 12, 2011 | 10:09 AM
riverrat68's Avatar
riverrat68
Thank you so much. The word "exactly" plays the major part. Thank you again .
Jerry
Old Jul 26, 2011 | 12:59 PM
bdog's Avatar
bdog
Subscribed!!! I need to do this this weekend as my c6 z shocks are in! Any pics anybody????
Old Jul 26, 2011 | 02:54 PM
bdog's Avatar
bdog
Unfortunately I sold that I have a standard c 5 now
Old Jul 26, 2011 | 03:27 PM
Evilash's Avatar
Evilash
I'm changing mine out also.
I bought the 4 resistors for the shocks but I didn't think about the level sensors.
I want to remove that stuff too. Is it the same value resistors I need for their circuit?
Thanks,
Old Jul 26, 2011 | 04:48 PM
riverrat68's Avatar
riverrat68
I did these already. I think that Z06 are a breed that doesn't need them. also the 2003 has a differant set up. But if you do, Do it in the exact steps...otherwise you will have to start over (in my case more than once) I still had to find a "tech II " to change the programing.
If I had to do it all over, I would have kept looking for a good set at a salvage shop.
Old Jul 26, 2011 | 05:37 PM
bdog's Avatar
bdog
Any pics of the installed resistors? ???
To shock simulators
