Trouble with Build
Old Mar 10, 2011 | 05:29 PM
Daddyrama31's Avatar
Daddyrama31
Default Trouble with Build
Started the install of some new AI Heads. When she was apart, we noticed abnormal lifter and cam wear. All 16 lifters were grooved as well as the lobes on the cam. The Cam has less than 5k on it. I think it may be an issue with the cam hardning. So it looks like a new cam and lifters are in order. Since thats the case, going to put in a larger cam.
Old Mar 10, 2011 | 05:31 PM
lucky131969's Avatar
lucky131969
Originally Posted by Daddyrama31
Took my car to the builder to install some new AI Heads. When she was apart, he noticed abnormal lifter and cam wear. All 16 lifters were grooved as well as the lobes on the cam. The Cam has less than 5k on it. We think it may be an issue with the cam hardning. So it looks like a new cam and lifters are in order. Since thats the case, going to put in a larger cam.
Is there a question?
AU N EGL's Avatar
AU N EGL
or was it a larger cam that caused the problem in the first place ?
Old Mar 10, 2011 | 05:37 PM
Daddyrama31
Cam was small XER cam 224/228 588/581 114+4 LSA. Have you seen this type of issue before? I saw it with my own eyes so I know it true. Just wondering what can cause this when all 16 lifters show abnormal wear. Just trying to learn.
Old Mar 10, 2011 | 06:02 PM
zeevette's Avatar
zeevette
A few years back Comp cams had a batch of poorly hardened lobes, IIRC. I like the cam you're taking out. Just about right for a street car. If you mostly street drive, I'd go no larger than about a 228/234, and keep lift under .600 for longer spring life. Get the best springs you can.
Old Mar 10, 2011 | 06:05 PM
vettenuts's Avatar
vettenuts
Curious what springs you are running when this happened.
Old Mar 10, 2011 | 11:48 PM
Daddyrama31
Comp 918's
Old Mar 11, 2011 | 09:34 AM
rebelheart's Avatar
rebelheart
Sounds like you had a whole bunch of metal shavings floating around in your engine,hope you didnt damage the bottom end!
Old Mar 11, 2011 | 05:43 PM
Daddyrama31
Bottom end is fine. No issues there at all.
Old Mar 11, 2011 | 06:44 PM
zeevette's Avatar
zeevette
Comp 918's
Comp918s were also known to have issues at one time.
Old Mar 11, 2011 | 09:35 PM
C5-vette's Avatar
C5-vette
http://forums.corvetteforum.com/c5-p...-camshaft.html
Any interest in this cam?
Old Mar 11, 2011 | 10:32 PM
Daddyrama31
No sir! I picked up a cam motions cam a little more aggressive then my last. 224/230 595/595 113+4 lsa. I will give everyone an update as soon as she is bolted back up!
Old Mar 11, 2011 | 11:19 PM
4DRUSH's Avatar
4DRUSH
Sounds like your next thread will be titled "Build got me in Trouble"
Good Luck
Old Mar 12, 2011 | 01:35 AM
C5-vette's Avatar
C5-vette
To Trouble with Build
