Fuel Gauge problem
Old Apr 30, 2011 | 11:10 AM
nmateo's Avatar
nmateo
Cruising
Default Fuel Gauge problem
Hello All I am having a problem with my 97 C5. After i fill the gas tank and drive it for about 40-50 miles the gauge goes from nearly full to reserve fuel then it resets at around 3/4 back to normal and then it does it again when it’s about 1/2 tank and drops down to empty. Please advise.
Old Apr 30, 2011 | 12:28 PM
Vettmann17's Avatar
Vettmann17
Typical issue, dicussed a million times. Before spending $$ for a fix try about 2-3 applications of Techron fuel additive. Buy the 20oz bottle and put one in with every fillup for the next three or so times and most likely it will solve the problem. Good luck bro!
Old Apr 30, 2011 | 12:31 PM
vettenuts's Avatar
vettenuts
Not sure what type of fuel you are buying but in the north Shell is about the only Top Tier fuel available, which is supposed to have a reduced sulpher level that is the cause of this issue.
Old Apr 30, 2011 | 12:37 PM
Vettmann17's Avatar
Vettmann17
Top Tier gas station list for the USA:
76 Stations
Aloha Petroleum
Chevron
Conoco
Country Mark
Entec Stations
Exxon
Holiday Stationstores, Inc.
Kwik Trip / Kwik Star
MFA Oil Co.
Mileage Stations
Mobil
Phillips 66
Quik Trip
Rebel Oil
Road Ranger
Severson Oil
Shell
Texaco
The Somerset Refinery, Inc.
Tri-Par Oil Co.
U.S. Oil
Old Apr 30, 2011 | 01:22 PM
guido7834's Avatar
guido7834
I also recently experienced this. Funny thing, it never happened in the 2 plus years I owned my 02. I recently added a bottle of Techron fuel system cleaner. About a month later, this happened. Coincidence?
Old Apr 30, 2011 | 06:08 PM
nmateo's Avatar
nmateo
Cruising
Right on thanks guys, I will do that. I also read the post before mine and saw disconnecting the cable by the rear wheel and connecting it might do the trick. I didn’t know that info on the gas. thank you so much. I figured I always filled it up with premium but the gas station matters. No more WAWA
Old Apr 30, 2011 | 08:51 PM
Jumper11's Avatar
Jumper11
I got an 02 as well and had the same issue. Autozone had a sale on the 12oz bottles, buy one get one free. I got as many as I could. Mine cleared up after the second fill up with Techron. Now I put one in every 3rd tank just to keep ahead of it. Good luck.
Old May 3, 2011 | 11:19 AM
bighank's Avatar
bighank
Default Techron Techron Techron and occasional Seafoam
Had sending units replaced under warranty. Good for about 2 years.
When I get dreaded guage to ZERO and check guages light use a bottle of Techron or Seafoam in the tank. Sometimes have to do this twice.
C5 sensors very sensitive to sulphur or whatever in the gas. Shame on Chevrolet. My Pontiac and Ford can run on any gas and not have this problem. Be glad you don't have a Jag and have to tune it every 2 or 3 months.
To Fuel Gauge problem
