Injector Special!!
Old May 3, 2011 | 03:36 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Default Injector Special!!
Got a deal for all my friends here.
BRAND NEW Bosch Design 4
With harness adapters, no cutting or splicing required!
ANY SIZE 24 FOR STOCK REPLACEMENT. AND 27, 30, 32, 36, 40, 42 AND 60LB VERSIONS!!
$299 for the set! And Free shipping!!SOLD OUT at this price!!
Flow matched sets, viton o-rings installed, our 1 year no questions warranty, and the best customer service you can get.
Reply or PM me for more details or to place your order!
Rich@fuelinjectorconnection.com
Old May 4, 2011 | 04:33 PM
FICINJECTORS
Supporting Vendor
Free shipping bump!
Old May 4, 2011 | 05:04 PM
blownnastyc5's Avatar
blownnastyc5
that is very tempting, I need to have my siemens 60's checked, I am not 100% trusting them
Old May 4, 2011 | 05:13 PM
FICINJECTORS
Supporting Vendor
Blownnasty, We also do full injector servicing and restoration.
THE SERVICE INCLUDES:
1) Injectors are externally cleaned, visual inspected
2) We test injectors for resistance, shorts, and current draw.
3) We perform leak test, spray pattern, and flow rate testing on one of our 3 ASNU flow benchs. All data is recorded and sent to you.
4) Remove filter baskets, o-rings, and pintle caps. Metal injectors are bead blasted to remove old paint and rust from the injector body.
5) The injectors are placed in a heated ultrasonic bath to insure that the injector is free of dirt and contamenants that could hinder the rest of the process.
6) The injectors are now put into another ultrasonic system while they are pulsed allowing the ultrasonic energy to dislodge any particles and build-up inside the injectors.
7) The injectors are now back flowed to remove all debris, etc.
The injectors are now returned to the flow bench for retesting of all functions. The data from this test is returned to you in detail with your injectors.
9) The injectors are now refinished with high temp paint. the stainless steel injectors are polished to a high finish.
10) One of our techs. now reassembles the injector, using all new parts.
11) The injectors are then vac sealed and packaged for shipment along with the old parts.
Prices are
$15 per injector for top feed
$20 per injector for side feed.
Usual turnaround time is around 1 week.
~Rich
Old May 5, 2011 | 06:53 AM
blownnastyc5
I may have to take you up on that! How many issues have you guys seen with the Siemens 60's?
Old May 5, 2011 | 05:19 PM
FICINJECTORS
Supporting Vendor
Blownnasty, if they are real Siemens then you shouldn't have any issues, but there are several knock offs around. Most of what is on Ebay are Chinese Siemens copys, and those will cause you headaches.
Update as well. Out of the 25 sets we had at this introductory price, only 1 is now left, I will post up when it is gone. After that price goes up to $389 (bosch raised pricing)
~Rich
Old May 5, 2011 | 05:57 PM
FICINJECTORS
Supporting Vendor
Sold out at that price!
Congrats to all who got a great deal on some fantastic injectors!
I'll continue to offer free shipping for a while for those who did not get in.
~Rich
Old May 5, 2011 | 11:22 PM
blownnastyc5
These are what came with Andy's blower kit from A&A Corvette. I've taken them off and checked them with the meter, they all checked out fine to me. But on the dyno they claimed two cylinders was red hot and blamed it on the injectors..... So IDK, I didn't see it myself and haven't had the chance to put it back on the dyno. According the the scanner they are only at about 68-70% duty cycle at WOT.
Old May 6, 2011 | 09:56 AM
FICINJECTORS
Supporting Vendor
Very interesting. Sending you a PM.
~Rich
Old May 8, 2011 | 12:52 PM
FICINJECTORS
Supporting Vendor
Happy Mothers Day!!!
Old May 8, 2011 | 01:22 PM
LoneStarFRC's Avatar
LoneStarFRC
Are these Bosch Design 4 the latest design from Bosch? Better injector?
Also, are the ratings (ex: 42 lb/hr) made at 43.5 or 58psi?
Edit: Sorry, forgot to ask if they are available for LS7s?
Old May 8, 2011 | 04:37 PM
FICINJECTORS
Supporting Vendor
The Design IV is Bosch's latest injector, it is the EV14 used in the LS3/7/9 but in a full length size. I have injectors for LS7, although the Design IV listed above is in LS1/6 length.
The sizes above are rated at 43.5psi. My EV14 shorts for LS3/7/9 are rated at 58psi.
Example, instead of a 42lb for the LS3/7/9 I have a 50lb @ 58psi. I have them in sizes from stock replacement, up to 208lb @ 58psi.
~Rich
Old May 8, 2011 | 07:53 PM
REZ1's Avatar
REZ1
Default injectors
I did business with rich when I had My c4..incredible customer service
a set of his injectors made My vette new again....this is the go to Guy
Arnie
Old May 8, 2011 | 08:33 PM
LoneStarFRC
Originally Posted by FICINJECTORS
.........Example, instead of a 42lb for the LS3/7/9 I have a 50lb @ 58psi. I have them in sizes from stock replacement, up to 208lb @ 58psi.
~Rich
Would you PM me more info like brand, part number and price please?
Old May 9, 2011 | 01:33 AM
FICINJECTORS
Supporting Vendor
Arnie
Thank you very much Arnie!
LoneStarFRC. PM sent
Old May 9, 2011 | 08:13 PM
FICINJECTORS
Supporting Vendor
All PM's replied to. Thank you everyone
Old May 10, 2011 | 10:54 AM
FICINJECTORS
Supporting Vendor
All orders so far will be shipped out today.
Thank you!
Old May 11, 2011 | 03:47 PM
FICINJECTORS
Supporting Vendor
Little bump!
Free shipping continues for 2 more days!!
To Injector Special!!
