Need help 2002 c5 won't start
Old May 17, 2011 | 12:42 PM
mattsc's Avatar
mattsc
Default Need help 2002 c5 won't start
I have 2002 C5 manual that will not start, it turns over fine, has fuel pressure but has no spark out of any of the 8 coils. I have checked all the mini and max fuses in both fuse boxes. Anybody have any ideas...it would be appreciated
Old May 17, 2011 | 12:48 PM
lucky131969's Avatar
lucky131969
Any recent work done?
Do you have a scanner capable of reading RPM? If so, that's the first thing I would check, to see if the crank sensor is providing an output. Have you checked 12 volts and ground to the coil packs?
Old May 17, 2011 | 12:49 PM
NotScared's Avatar
NotScared
St. Jude Donor '23, '25
This. If no power at the coils, work backward and check the ignition relay.
Old May 17, 2011 | 01:06 PM
mattsc's Avatar
mattsc
There are only 2 old 'body' bcm codes from long ago. And Thanks for all the replys..
I will check the IGN relays but i think there are several of those.
Old May 17, 2011 | 01:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
fuses?? pcm #16
bc
Old May 17, 2011 | 01:44 PM
mattsc's Avatar
mattsc
What I ment was I check EVERY mini and maxi fuse and they were all good so maybe a relay?
Old May 17, 2011 | 02:21 PM
lucky131969
Do you have a meter? ....have you checked for 12 volts/ground to the coil packs yet?
Old May 17, 2011 | 02:30 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On top of EACH fuse, there are TWO small slots. They are TEST POINTS. Read both of those test points to ground and you should see battery voltage (make sure that the appropriate circuit is ON if required!
BC
Old May 17, 2011 | 02:43 PM
mattsc's Avatar
mattsc
Checking...
Old May 17, 2011 | 05:08 PM
mattsc's Avatar
mattsc
Ok there is 12 volts at all 8 coils in the pink wires . and ALL fuses check out fine . and I swaped the ign relay and still the same...?turns over fine but no start?
Old May 17, 2011 | 06:09 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well, you either have a missing/loose ground OR the PCM is not firing any of the coils! How are you reading the DTCs? Are there any CEL or dash messages?
Old May 18, 2011 | 10:57 AM
mattsc's Avatar
mattsc
Thanks Bill,
There are no ground problems . So the PCM could be the culprit. When it went down it was driving and melted the drivers side 02 sensor wires on the headers and oil pressure sending unit wires and stalled but thats it . and they have been repaired. What about the Crank and Cam sensors???
Thanks Bill
Old May 18, 2011 | 11:19 AM
mattsc's Avatar
mattsc
Also, there are no codes on the dash or on HP tuners.
Old May 18, 2011 | 11:57 AM
C4happy's Avatar
C4happy
You need to check RPM while cranking to see if you are getting crank sensor input if you are reading RPM while your starter is spinning you engine you are getting crank sensor singnal if not you need to find out why you crank sensor isn't working?
Old May 18, 2011 | 04:52 PM
mattsc's Avatar
mattsc
There is no movement in the RPM'w on the dash rpm gauge while cranking..SO?
Old May 18, 2011 | 05:49 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Check for cranking RPM's with a scan tool. You won't see it on the instrument cluster tach while cranking.
Old May 18, 2011 | 06:27 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Did you wash your car before this happened? The only reason I ask is mine did the same exact thing after I washed my car and it turned out there was water in the 2 plugs that go to the pcm...........Paul
To Need help 2002 c5 won't start
Old May 19, 2011 | 08:08 AM
Quicksilver Vert 01
Post #13 tells the history and probable cause.
Old May 19, 2011 | 05:28 PM
mattsc's Avatar
mattsc
Nothing was wet , it was on the road when it went down. All wires have been repaired all grounds checked and the crank sensor replaced and it still has no spark. I will have the PCM check..
Old May 19, 2011 | 05:54 PM
fsuforever's Avatar
fsuforever
Sounds like ur outta gas man,
