durability of engine block c5?
Old May 30, 2011 | 11:08 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by sccs
http://www.summitracing.com/parts/AAZ-58-544/?rtype=10
this is what i ordered. but from rockauto.
got it today. finally. i hope i didn't make any mistake and ordered a wrong one? i have a LS1 motor 1998? Tomorrow we will replace it,
So many things i have to do this week, i have to repair my hand brake, replace water pump, Technical review, pay new insurence.
Its just banging my purse.
There are TWO different LS1 water The one above and one with a pressed on one piece drive pulley. Look on the front of the black drive pulley and see if there are four nuts on studs. If there is, you have the correct pump. I cant remember IF, the newer one is interchangeable with the old.
You will also have the old felt (DIFFICULT TO SCRAPE OFF THE BLOCK) gaskets. That will be the worst part of the pump change! Make sure to get all the OLD gasket off the block!!
Make sure that the pump comes with TWO the new style metal/O ring gaskets or you will have to purchase TWO. If it comes with the OLD STYLE gaskets, you can still use them but the new ones are better.
BC
Old May 30, 2011 | 11:21 AM
sccs's Avatar
sccs
BC
omfg. .. i hope i didnt order wrong one.
im sorry but i dont know what studs.. can you tell from pictures of the above link if its the right one?
Old May 30, 2011 | 11:40 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If there are FOUR NUTS on the front of the pulley,,, you have the correct one. If there are NO nuts, you will have to figue out if the new style pump is interchangable. Simple as that.
If it anything like my 98,, you got the correct one. My 98 was an early car.
Old May 31, 2011 | 06:40 AM
sccs's Avatar
sccs
water pump was today replaced, worked everything well, till now, im very happy to have my car back <3
Old May 31, 2011 | 08:57 AM
WKMCD's Avatar
WKMCD
Great news!
Old Jun 1, 2011 | 10:52 AM
johnnyzvette's Avatar
johnnyzvette
I'm glad you got it fixed! See, no worries! You have a great car, enjoy it!
Old Jun 2, 2011 | 11:55 AM
sccs's Avatar
sccs
Today i had tehnical review. When he was pressing the gas.. after 1 minute or so.. it started to steam of the hood like crazy.. i never seen something like this, temparature got quite high also.. but not at red, the cap was blown down i think - I HOPE its only the cap that is in bad condition....we waited a little so it cooled down. and ****inued to pass the review.. after that they got a search under hood.. wee cooled it again. refilled water. it started to boil. cooled even longer.. added water. was good for some time. i parked it out side and we were watching the coolant tank.. and i think it started to boil again...
Possibility of destroyed head gaskets?
this is geting worse and worse. Ill go later on to check at idle what happens.
Old Jun 2, 2011 | 04:11 PM
Dope's Avatar
Dope
Resident moron
Check your oil. If it has coolant in it (looks like a chocolate milkshake) then you might have a bigger issue (like a headgasket).
Where was the water coming from that was steaming?
Dope
Old Jun 2, 2011 | 04:16 PM
sccs's Avatar
sccs
Dope
i have opened a new thread so every one willing to help can see it
http://forums.corvetteforum.com/c5-t...lant-tank.html
water/steam came only from coolant tank. currently we filled up only regular water
