Lost piston #7 AGAIN
Old Jun 13, 2011 | 11:46 AM
futuretech's Avatar
futuretech
Default Lost piston #7 AGAIN
Lots of drag racing - stock short block. Number seven is chipped in upper right corner showing the ring. Here is the question.
I have 370 rwhp. Don't need any more.
I have ARP bolts in the rods and a small cam with harlen rockers
Will Forged pistons ALONE eliminate the damage (assuming it is a lean condition) or do I need forged rods too?
By the way. What happens in a lean condition WITH forged pistons? Is there still a risk of other damage?
Old Jun 13, 2011 | 11:57 AM
lucky131969's Avatar
lucky131969
Just curious. What intake manifold are you running, and how are the rear coolant bleeds hooked up?
AU N EGL's Avatar
AU N EGL
Nope need better oiling.
#7 goes as it gets starved for oil
and you want run er RICH
Old Jun 13, 2011 | 12:03 PM
futuretech's Avatar
futuretech
LS6 intake. Closed back port.
First engine with same problem was LS1 with back crossover
Old Jun 13, 2011 | 12:04 PM
futuretech's Avatar
futuretech
Has high output old pump - always over 40
Old Jun 13, 2011 | 12:19 PM
lucky131969
Thanks. Both engines tuned by the same shop?
Old Jun 13, 2011 | 12:21 PM
futuretech's Avatar
futuretech
Yes
Old Jun 13, 2011 | 12:28 PM
lucky131969
Yes
Ok. First to address your question. Yes, forged pistons will hold up much better to abnormal conditions, compared to hyper-eutectic pistons. Forged rods will provide more stability, ARP bolts to prevent stretch, etc.
......the tuner is one possible common denominator.
Old Jun 13, 2011 | 12:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
AU N EGL
How do you improve oiling to just ONE cylinder? If theres a way,, Im game!
I added a Melling high volume oil pump to my engine and I have good pressure at idle and at high RPMs. What else can prevent the #7 issue??
Old Jun 13, 2011 | 12:36 PM
mchicia1's Avatar
mchicia1
How does one lose a piston on an N/A motor only pushing 370 rwhp? Maybe your tune is the culprit.
Old Jun 13, 2011 | 12:49 PM
rebelheart's Avatar
rebelheart
I suspect a lean tuning problem causing detonation.This is NOT an oiling problem.Forged pistons and a different tuner should cure your problem.
Old Jun 13, 2011 | 12:51 PM
mchicia1's Avatar
mchicia1
I say too much timing advance.
Old Jun 13, 2011 | 12:54 PM
futuretech's Avatar
futuretech
Hard lesson but I think you are correct. Can I used forged pistons and my stock rods?
Old Jun 13, 2011 | 12:56 PM
rebelheart's Avatar
rebelheart
Yes you can,LS1 rods are quite good but use good new rod bolts.
Old Jun 13, 2011 | 01:17 PM
futuretech's Avatar
futuretech
I have ARP bolts from the previous build. I assume they are ok to reuse.
Old Jun 13, 2011 | 01:23 PM
bracketshark's Avatar
bracketshark
Were the same injectors used in both motors in the same location? If so #7 may not be working 100% for whatever reason. Air leak on that cylinder makes since also. I'm wondering though how forged rods add stability to a rotating assembly. I agree with reliability. Oh well JMO.
Old Jun 13, 2011 | 01:53 PM
Xtreme Z06's Avatar
Xtreme Z06
Injector is the first thing I would look at. It is not an oiling issue. LS1's and LS6's have had this issue for years in C5 Vettes. Lean condition is present..
To Lost piston #7 AGAIN
Old Jun 13, 2011 | 02:17 PM
futuretech's Avatar
futuretech
Same injector, same spot both engines. How can I get injectors tested? BTW LS1 injector used on LS6 engine.
Old Jun 13, 2011 | 02:22 PM
lucky131969
Depends on the year. If I remember correctly, the 2000 injectors were smaller (26 lbs)....than the LS6 28 lbs.
Old Jun 13, 2011 | 02:49 PM
Filapoosis's Avatar
Filapoosis
Fuel injector connection can flow test your injectors. I would try that out.
