So just got off the phone with texas speed and the rep. said:
-I cant use an LS2 block for a 402 stroker motor if its been bored .030?Cause he said its "trash"?
-Using a big cam (like MS4 or bigger) with FI wont help with power,and I will actually make MORE power with a smaller cam?That using a big
cam is the opposite of whats right?
I was gonna ask about what pistons to use but didnt have a chance cause he hung up
So I figured Id just double check with you guys if those two things are true.
i thing the FI & cam issue kinda depends on the type of FI you're using. i can see a bigger cam working better/gaining more with a top-mount than with a turbo or centri, but even then, you still have to have good timing on the valve events to retain your boost
Instead of relying on forum BS, why not contact ECS, Corvettes of Westchester, etc. Tell them what your goals are, and find out what is possible.
Lol well I thought calling TSP would have been it but idk maybe it was just the way the rep. came off to me. I just felt like hearing from other people. but thanks guys
If it comes to that, I really dont mind the Compstar.
Btw thanks Kevin!
I think Callies says the Compstar is good to 1000HP or so. All finish machining is done state-side. Eagle, SCAT and a few others are off-shore forgings. I run an Eagle with no problems at all.
I would suggest you buy some books and do a lot of reading on building high performance LS engines before you start ordering parts for an 800 hp engine build. The questions you are asking are very basic knowledge for an engine builder. It is very important that you match the parts in the engine for your expected performance level, driving habits and power adder. You will need different pistons, camshaft, compression ratio, head gaskets, studs, etc based on naturally aspirated, centrifugal supercharger, roots supercharger, turbo, or nitrous oxide. You can't choose a piston crown/dish until you determine what compression ratio your build needs and you know what combustion chamber volume your heads will have.
Plus there is more to building an 800 hp engine that simply assembling a pile of parts. It may be time to start talking with an engine builder for this level of performance...
