Plug Wires
Old Jul 5, 2011 | 08:51 AM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default Plug Wires
Planning on changing out my current stock plug wires and plugs when moving to headers. What I see a lot of offerings on the vendor lists, but looking for feedback on what you may have used or use now or to stay away from. Also cool sox or not for insulation of wires? Thanks
Old Jul 5, 2011 | 09:11 AM
vettenuts's Avatar
vettenuts
I had MSD and wasn't happy that they didn't "click" into place very well. I then went with the GM LS7 wires, which have a 90* plug end. These fit well with headers, are very good quality and click nicely into place. I have been very happy with these wires.
Old Jul 5, 2011 | 10:27 AM
baxsom's Avatar
baxsom
I am using the standard GMPP wires with the oem metal heat shields with my texas speed headers. No issues. The GMPP wires give a good positive click onto the plug as well.
Old Jul 5, 2011 | 02:19 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
gmpps and I added a coolsox type cover with the factory metal heat shield as my dynatechs are not coated.
Old Jul 5, 2011 | 03:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GMPP Red Performance Wires and Im very happy with them. They fit 100%, and flat work. DO NOT be HYPED with all the FANCY HP BS that some wires spew! There is ZERO horsepower to be gained by wires or plugs!
Purchase wires for QUALITY/FIT and DURABILITY! The GM PERFORMANCE RED WIRES will not let you down...
Gene Culley has them for a great price. www.gmpartshouse.com
BILL C
Old Jul 5, 2011 | 08:57 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Some of the very best wires on the market right here and the bets deal you will find on them:
http://forums.corvetteforum.com/c5-t...-anywhere.html
MSD feature a posi loc system, if they didn't click for someone they weren't on all the way.
Old Jul 5, 2011 | 09:10 PM
Quick Draw's Avatar
Quick Draw
I agree. Plugs and wires for $70 bucks! I jumped all over this.
Old Jul 5, 2011 | 09:14 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
MSD's with coolsox covers to help out with my headers. Also, mine clicked.......
Old Jul 5, 2011 | 10:38 PM
Rex99Coupe's Avatar
Rex99Coupe
Anyone make plug wires a little longer than stock? I may have to add a spacer to my valvecover or a taller valvecover because of shimming for Yellaterra rockers.
Old Jul 5, 2011 | 10:44 PM
egrand333's Avatar
egrand333
When I changed the plugs on my brothers 2000 something Tahoe I broke a wire and replaced it with one of the old ones from my 97 vette. The vette wire barely reached but did work, so the Tahoe wires were a bit longer but looked excactly the same. I think the plugs were the same as the Vetts also.
Old Jul 5, 2011 | 10:57 PM
0331MARINE's Avatar
0331MARINE
I'm pretty sure 99blancoss can have the MSD's made how ever long you need them.
Old Jul 6, 2011 | 12:07 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you need longer wires, he the go to guy!
BC
Old Jul 6, 2011 | 12:10 AM
99blancoss's Avatar
099blancoss
Former Vendor
Thx guys, yes we custom make them to any length or boot you need.
Old Jul 6, 2011 | 12:21 AM
SG Lou's Avatar
SG Lou
Pushing close to 54k on factory wires and plugs in my 04. Whats the recommended plug to use ? No mods done to the motor.
Old Jul 6, 2011 | 06:42 AM
baxsom's Avatar
baxsom
at 54K they should only be at half of their lifespan. You cant get better than oem in this one case.
Old Jul 6, 2011 | 06:56 AM
lucky131969's Avatar
lucky131969
.....provided you don't have headers....
Old Jul 6, 2011 | 12:00 PM
99blancoss's Avatar
099blancoss
Former Vendor
The plugs you have are probably ac delco 41-110... they are a better plug as in they will last longer than a Tr55 or TR6.. They are rated at 70,000-100,000 miles .. so unless they are degraded at all your better off with what you have.
To Plug Wires
Old Jul 6, 2011 | 12:22 PM
baxsom's Avatar
baxsom
what do you mean?
Old Jul 6, 2011 | 04:55 PM
SaberD's Avatar
SaberD
BILL C
with headers, you are going to need some quality wires for them to hold up to the heat. i would also suggest koolsox in combination with some zip ties to keep the wires away from touching the headers if needed. I have been using the gmpp red wires and koolsox with great results. burnt out a set of autozone wires before I learned my lesson .
Old Jul 6, 2011 | 08:04 PM
lucky131969
what do you mean?
It means, that exposure to high heat (over time) degrades the plug wires. Even with kool sox, it would be a serious stretch, to get 100k out of a set of wires if you have headers.
