233/239 cam w/stock manifolds
Getting a cam that has more lift than where the heads flow max is definitely a good idea, think about it, you pass that lift and max flow TWICE, on the way open, and on the way closed. Anyways, looking at the lift of the cam means that you are worried about the wrong thing. You pick the rpm range you are running in, then pick the lobe, and let the lift fall where it falls. Lift is the least important of all the factors.
Lift is one of the most important factors for RELIABILITY not necessarily HP. We see so many high lift cam engines go boom because of the wrong choice of cam and springs.
Cams with lift higher then the heads flow is useless. Match the cam to the flow of the heads for best results.
the cost to take off and port yyour 241 heads are about the cost of good 243 ported heads.
I ported my 241 heads and they did almost nothing. So I bought 243 heads then cleanied them inside.
I will be porting at home. i have done maybe 4 or 5 sets of SBC heads so this will be my firts attempt at LS heads... how much you pick up your 243's for?
Yes, you definitely could. Pull the valves, clean the bowls, raise the roof, but don't lower the floor. You stated that you have ported heads before, so this should be a non issue, just clean them, don't port them. You will be just fine.
If you were asking about purchasing heads, I would say buy 243's as stated, but you are asking if ported 241's will run better, and yes they will. Good luck. Steve
