Manual transmission question
Old Jul 18, 2011 | 04:52 PM
  #41
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by LoneStarFRC
Dexron VI was formulated for fuel economy purposes primarily.
I'd be interested in where you are quoting this from. Everything I've read, including GM's own documents quote a number of reasons for improving the fluid, but none I've read ever mentions "fuel economy purposes".
My references are GM doc 2622890 and the one I included in the earlier posting.
Old Jul 18, 2011 | 08:25 PM
  #42
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
From the Sandyblog article on Dexron VI:
"...the fluid has the potential to enable improved fuel economy..."
Doesn't really state that they designed it for better fuel economy, but given the entire industries push for lower viscosity fluids, doesn't seem like a stretch to me to believe that the reason the viscosity of Dexron VI is about 40% lower than that of Dexron III is to improve fuel economy.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 18, 2011 | 10:23 PM
  #43
Eric D's Avatar
Eric D
Subdriver, thanks for pointing that out. For anyone else that might want to read it directly, here is the LINK.
Here is part of the article that others might find interesting:
TIP: Since some early bulletins were issued, further validation has taken place and certain transfer cases and manual transmissions now DO use DEXRON-VI, so it's important to refer to the owner manual for appropriate recommendations.
All licenses for DEXRON-III expired at the end of 2006 and will not be renewed. Fluids sold in the market after that date bearing claims such as "suitable for use in DEXRON-III applications" or similar wording should be avoided, because 'DEXRON-III' fluids are no longer checked and policed by GM and therefore may not be the originally tested and approved formulation.
Keep in mind that this article was published back in 2009, over two years ago by Roy Fewkes and Joan Petit. I've had Dexron-VI in my 2000 6-speed for well over a year with more than 20K miles on the fluid. My tranmission shifts like new, maybe even a little better than new.
I'm going to try and get in touch with Mr. Roy Fewkes and see if there is a later update. If not, see I he might write one.
