Active handling really getting goofy now...
I later drove it about 70 miles and it ran on cruise all the way. On the way back 8 hours later it ran about 30 minutes on cruise then disengaged and when it did I felt it brake a little. I waited until I was nearly home and tried it again and it hit one of the brakes hard. When I got home I pulled the codes and there were none.
I have cleaned the ground packs by the radiator (they looked ok except for paint on the studs) but haven't had time to go any further. Does this sound like a ground, a swps or something else? It has been suggested that it is the swps and if so I don't mind replacing it. I just don't want to go to all that work and it really be a ground or something.
you must have a codeI have a SWPS that needs replacing and I get a C1287 when it drops out. If you watch the DIC when the AH starts to play up you'll see an active handling caption. At that point, the cruise will trip out. Once you get a full failure with the service active handling et al, and you have the little yellow skidding car on the IPC, you can reengage the cruise and it will stay in.
The cruise trip is a consequence of the AH problem not a problem in its own right.
When the car acts up the DIC flashes active handling then cruise disengaged. I usually just turn the AC off, hit resume on the cruise and everything is good. I don't want to drive it all the time with the AC turned off but its getting spooky to drive now that it is applying one of the brakes.
Thanks for the help I hope I can find the problem.
P275/40ZR18 103W Nitto Extreme on the rear
They are fairly new as far as miles go but I think they were put on before the previous owner. He said the dealer took off the run flats and put these on.
Could that be the problem?
The data logger sounds like a good idea, I live about a hour from Wichita Falls and a little more from Fort Worth. Is there someone there that can do that? I don't know if anyone at our small town dealer can or not. They are more into fixing pickups and suv's.
Hows your alignment? Is your steering wheel DEAD NUTS CENTERED when you driving straight down a level road??
Annalignment issue can trigger AH as the wheel is off center and the car is going straight. The EBTCM thinks it needs to correct by engaging AH to get the car to go in the direction of the off centered wheel.
BC
BC
As far as alignment goes it drives like a dream, no pulls and tire wear seems non existent so far. Thanks for all the help everyone
We have been working 7 days a week so I don't have much project time right now. I will have to nibble on this a little at a time.
BC
Went and drove the car but tried something different. I "wiggled" the wheel like I was making small corrections and the active handling activated in a very short distance, not after 30minutes to a hour like it usually does. Still no codes. I am thinking maybe my swps is going south and is too sensitive but still within range. Does that make sense or should I keep looking?
Dielectric Grease SHOULD NOT put in electrical connections. Especially very low voltage signal circuits. If your worried about corrosion, use a purpose made anti corrosion compound.
Try reading the DTCs IMMEDIATELY using the DIC when the AH acts up. Don't switch off the ignition. Just read the codes.
YES,, the SWPS could be bad but,, there are several other things that can cause the issue. The SWPS is the component susceptible to wear.
The SWPS connects to the EBTCM through C102 which is a 20pin connector in the RH sider rear engine bay wire colors LT GRN, LT BLU, LT BLU.
If you're familiar/have acces to one, using an oscilloscope or datalogging these (and/or other) signals may help to diagnose it rather than guessing (which is what the stealership may do while charging you for all of the wrongly guessed parts
). Not sure if a datalogger such as this would work...
http://www.plxkiwi.com/kiwiwifi/
Related modules/sensors/signals that look to be involved with automatic brake control:
Electronic Brake Traction Control Module
Electronic Suspension Control Module
Powertrain Control Module
Instrument Cluster
Steering Wheel Positioning Sensor
Wheel Speed Sensors
Lateral Accelerometer
Yaw Rate Sensor
Perhaps someone could POST UP THE WIRING CHARTS related to the antilock brake system (i have paper manuals).
My mistake I thought dielectric grease was a conductor. I have some ACF50 would that be the right thing to use?
I have read them both ways but will try to read them without shutting off the key from now on.
Instrument Cluster
Wheel Speed Sensors
Yaw Rate Sensor
If it were me, I'd disconnect C102 and have a look at the terminals just to make sure nothing is wrong there. If all looks okay, reconnect and try it one more time. If the problem persists, then I would replace the SWPS.
