Remote bleeder hose leaking
Old Dec 29, 2011 | 09:33 AM
vettenuts's Avatar
vettenuts
Originally Posted by rttmike
When I bought my car (3 months ago) it had the remote bleeder. The previous owner mounted it near the manifold (not many choices other than that) and the car got warm at idle and burst. Needless to say the car was on a flatbed and on jackstands the following day. Dropping the exshaust, tunnel plate , and inspection cover to replace with a factory bleeder. This was a very tight fit and took about 6 hours. I will never install another one and I will now be in search of the vac setup. I don't need yet another reason to remove the driveline.
As bad as it sounds, I almost wish I would have bought an auto. I keep reading about so many clutch and hydrolic issues. Yuck.
There were issues with some vendors having very short extension lengths on the hose. I carefully routed mine up the frame to the top of the brake booster and have it tied there with a tie wrap. I have to admit I was unaware of all these issues and might have not installed it if I had known beforehand.
Old Dec 29, 2011 | 11:58 AM
bumble-z's Avatar
bumble-z
Originally Posted by striper
Anyone want to post what brand remote bleeder is leaking? I just bought one to install when I put my new slave in. Tell me now before it's too late.
From what I have read it seems the remote bleeders with the "crush washers" at the slave end, are the one's that have leaked.
Regardless of which one you choose, make sure the line is covered with a cool sock, sleeve,etc & routed to keep from the heat & also buffer it from rubbing a hole in it or on things like a fuel line (NOT GOOD!)
Good luck.
Old Jan 14, 2012 | 09:50 PM
ZedO6's Avatar
ZedO6
The original GM slave has a standard brake bleeder taper, as do 100% of all automotive fluid bleed screws.
Any remote bleeder that uses a crush washer onto the rough cast GM slave is half assed and not a SAE compliant hydraulic line connection.
Would you use a standard bolt snugged down on a crush washer on your brake calipers? I thought not....
Old Jan 14, 2012 | 10:11 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Originally Posted by Eric D
ET, the guys in our shop that work exclusively on Corvettes uses the vacuum method at the master cylinder to remove entrapped air. Some of the newer GM vehicles with similar hydraulic clutch systems come without any bleeder at the slave and the vacuum method is the only option.
I’m sure it will start a lash back response from those who have already installed remote bleeders, but the fact is they are not needed, and as you pointed out, LOTS of issues from having them.
Having a remote bleeder installed it the easiest way to flush the hydraulic system of the contamination that causes the "sticky pedal". I've had one installed for over 2 years, flush out my system once a month, and have had no issues with leaks or with the clutch.
The issue could be that the parts are made from low quality material.
I agree that the vacuum method works well, but will not clean out the system.
