Stock LS6 + LS7 Lifters = ? Pushrod Length?
What length pushrods do I need to use LS7 lifters in an '02 LS6? Is it the same as the stock pushrods?
Thanks!
If you go to the GM dealership and ask for lifters for your car.......guess what you're going to get....LS7 lifter. They are the OEM replacement for ALL LS based engines...4.8, 5.3, 5.7, 6.0, 6.2, 7.0 etc.
In my research of the GT11 camshaft I found lots of folks claiming a large increase in valvetrain noise. It was no surprise that when I fired mine up the valvetrain was MUCH louder than before... definitely a "sewing machine". I have LG headers on my car and the valvetrain noise can be heard clearly inside the car beyond the noise of the headers at a steady cruise.
So I started looking onto what causes noisy valvetrains, and the most common issue seems to be incorrect lifter preload.
The two things that changed from stock as far as valvetrain measurements goes are:
1. The cam base circle. This cam has a .631 and .644 lift so the base circle must have gotten smaller by a significant amount relative to the LS6 cam.
2. The lifters. I'm using LS7 lifters which are, as mentioned above, supplied by GM as a replacement part for all LS engines. HOWEVER, it would appear the LS7 lifters have a shallower pushrod cup than previous LS1/6 designs making them roughly .060 "longer" (see post #7 for pics):
http://m.modernhemi.com/forums/showthread.php?t=1135101
The LS7 lifters may have a wider operating range of preload values (this I could not confirm by searching) which may/may not be why they still work as a drop in for the "shorter" earlier designs.
I'm waiting for a call back from Lingenfelter to confirm the base circle specs of their GT11 camshaft, this way I can at least see if the "math" method of determining pushrod length will point me in a different direction.
I also plan to pull a rocker cover tonight and check the preload the old fashioned way... by counting the turns of the rocker bolt from zero lash. This seems to be the only way to be sure. I will update with info as I learn more.
EDIT: I just noticed all of the data on the lifters is in Eric D's post above - fantastic!
