Melling HV Pump - Fit?
Old Aug 25, 2011 | 11:23 AM
  #41
Blue Angel's Avatar
Blue Angel
Originally Posted by About2Bite
my cam bolts coming loose a day after the install but that's a whole other discussion
DO TELL! Maybe I can avoid doing whatever it was that was done wrong!
Oil pressure is at about 70psi cold and when the oil fully warms up ~200* it's at about 35psi.
I replaced the high pressure spring with the standard pressure spring and I'd recommend you do the same.
That's the plan!
70psi cold? That sounds high, but to be honest I can't remember off the top of my head what my stock cold idle pressure was. Are you running 5W30? I use 10W30 and saw maybe a 1-2 psi difference, though it may just be in my head. Good to see it settles back to ~35 when hot - just what I want!
Old Aug 25, 2011 | 12:20 PM
  #42
Blue Angel's Avatar
Blue Angel
Originally Posted by Bill Curlee
If it were me,,, I would NOT bake the damper. Heating the ENTIRE HUB is a lot different than directly heating just the hub. It doesn't take much heat to get it to expand when you directly heat just the HUB. Were NOT talking cherry red!
Well I wasn't planning to COOK the damper, just warm it up a little in the oven... when a fork comes out clean it should be ready. I was just thinking to set the oven at ~220F and leave the damper in there for a half hour or so. I wouldn't think it would hurt it? 220F is just over the temp of boiling water, a temperature I would assume the balancer would easily exceed in say a road racing application?
I figured the oven at a preset temperature would be safer than guessing with a propane torch...
My pick up tube only had ONE bolt! ALL the C5 that I have ever worked on have only had ONE bolt.
As far as the O ring goes,,,,, that updated new thicker O ring seals a LOT better and it does fit fine. I used an inspection mirror to make sure that the O ring was properly inserted into the recess and NOT extruded out the side.
I'm pretty good at manipulating the screw and not dropping it in the pan BUT,,, I went ahead and put some paper towels in the opening to prevent it from getting away!
Make sure that you read and PRINT OUT the procedure on properly tightening the crank/damper bolt! FOLLOW THE PROCEDURE 100% and do NOT take shortcuts.
I made my OWN damper install tool from an old bolt and some all thread welded together. You need the tool to start the damper on to the crank!! Do not use the old bolt to start the damper as you may pull out the first few threads in the crank snout.
I also used a LARGE strap wrench to hold the damper still during bolt removal and bolt re-torque.. Using that procedure I can do the entire procedure MY SELF!
The two bolt pickup tube I saw must have been an aftermarket unit.
I'll do my best to get that new thick o-ring in there without screwing it up. I may just buy an inspection mirror for this as you suggested... I've lost track of the number of times I wished I had one!
I'm planning to switch off the earth's gravity for a few minutes while installing the pickup tube bolt... that aughta keep it outa the oil pan!
I'm planning to go strap wrench shopping this weekend, then looking for a monster breaker bar as well. I saw another guy who torqued the crank bolt to spec then prior to doing the 140 degree TTY procedure, he took a protractor and a Sharpie marker and just marked the angles on the bolt and damper. I was thinking of going one further and applying small dabs of paint that would stay on permanently, then I can easily see if the bolt ever tries to come loose. I'm pinning the crank as well, so that's not likely to happen but it couldn't hurt for a quick visual check and peace of mind.
Oh, I also splurged and got the ARP head studs over just the bolts. Totally unnecessary for a pretty much stock engine, but I bet they will be a joy to use over bolts.
Also, not sure if you're aware of this (you probably are), but there's a cooland jacket plug in the block above the starter that allows draining most of the remaining coolant out of the block and heads (as very little comes out using the rad's petcock). When I pulled my pass side head off only a trickle of coolant came out, hopefully I get the same result on the driver's side head.
The coolant out of my 120k mile '02 is clear as new! I'll replace it anyway due to its age, but it's good to see there's no oil or rustiness in it.
Old Aug 25, 2011 | 05:28 PM
  #43
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just saw this Melling Pump at Carisle in the Corvetes Of Westchester booth.
BC
Old Aug 25, 2011 | 08:25 PM
  #44
Blue Angel's Avatar
Blue Angel
Thanks for the pic! Mine will be here early next week!
Old Aug 26, 2011 | 12:01 PM
  #45
corvettebob1's Avatar
corvettebob1
"My pick up tube only had ONE bolt! ALL the C5 that I have ever worked on have only had ONE bolt."
I don't think so even my stock 98 pump has 2 bolts for the pickup screen.
And I do remember the one is a b*tch to get in with my hands.
Old Aug 26, 2011 | 02:32 PM
  #46
Lothar34's Avatar
Lothar34
My old screen had one, my new screen had one. Every one I've seen only had one.
Old Aug 28, 2011 | 07:22 PM
  #47
About2Bite's Avatar
About2Bite
That's the plan!
Here is my thread:
http://forums.corvetteforum.com/c5-t...this-week.html
Yep 70psi cold, it does seem high to me but once warmed up 35-40psi is good to me.
The h/v pump came with a high pressure spring installed, make sure you replace it with the shorter standard pressure spring, I'm sure my oil pressure would be through the roof with the high pressure spring.
Old Aug 29, 2011 | 10:09 AM
  #48
Blue Angel's Avatar
Blue Angel
Bummer about the cam walking! Did you ever get it sorted out?
I'm putting in a GT11 cam from LPE and your thread got me sweating a bit, so I called them this morning to ask if they do anything special to make sure their cams stay put when building an engine. Red Locktite and 30 ft-lbs was the answer, up from the factory spec of 26 ft-lbs.
Old Aug 29, 2011 | 04:02 PM
  #49
About2Bite's Avatar
About2Bite
I used loctite but only torqued them to factory spec, I got it done a few weeks ago and have been driving it since.
no probs since I used the plate and I don't have to worry about them loosening it out so I can sleep at night
