Turn Signals
Old 09-04-2011, 01:34 AM
rtriker
rtriker's Avatar
Default Turn Signals
Hi, I am having a problem with my turn signals not working on my 2000 vet. When they quit I can turn on my 4 way flashers and let them blink maybe 2 to 3 times and shut them off and try the signals and they will work for awhile usually and sometimes for quite awhile. I've checked the fuse for them in the fuse box under the passenger foot well and took out all of the small fuses and put them back in in the fuse box in the engine compartment and it still does the same thing. So was wondering if anyone has had the same problem or has any suggestions? Thanks for any help on this. Russ
Old 09-04-2011, 02:13 AM
cptinjak
cptinjak's Avatar
Do a quick search for hazard switch replacement. Should get the info you need. Or just press the switch lots of times every few days to try and keep the contacts clean.
Jack
Old 09-04-2011, 08:36 AM
0Tampa Tuning
Former Vendor
Tampa Tuning's Avatar
St. Jude Donor '12
I have a 2000 Vert Vet also. The last year or so, I started to have the same problem. I bought the relay harness which installs under the dash. Its made to reduce hyper flash on aftermarket tail lenses.
It worked on the flasher also. 15 minute job
Phil
www.TampaTuning.com
Old 09-04-2011, 09:52 AM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
This will fix it
http://shop.jwmotoring.com/product.s...2&categoryId=4
Directions are also available at that link
Old 09-04-2011, 08:24 PM
rtriker
rtriker's Avatar
Jack
Thanks Jack for your reply. I will try working the switch in and out a few times and see if that helps. So you think that the hazard switch is what's causing the signals to not work! Do you know how the hazard switch comes out? Thanks again, Russ
Old 09-04-2011, 10:41 PM
rtriker
rtriker's Avatar
Phil
www.TampaTuning.com
I don't have any aftermarket taillights, so are you saying that with the problem I'm having this harmess will still take care of it? Also where is the best place to order one and about what's the cost? Thanks Phil. Russ
Old 09-05-2011, 01:29 AM
shadowman1
shadowman1's Avatar
Do a search and you will find the fix for this. The turn and emergency flasher is 1 unit. What people are doing instead of replacing the whole flasher unit in the dash (where the button is) is locating the wires from your turn signal switch and installing a regular flasher from the auto parts store under the steering wheel. You can do this for under $10.00
Heres the thread for the fix
http://forums.corvetteforum.com/1569256474-post50.html
You don't have to buy the plug you can use 2 female spade connectors to the flasher.
http://forums.corvetteforum.com/c5-g...-problems.html
Dave
Old 09-05-2011, 03:21 AM
Rebel 1
Rebel 1's Avatar
Dave
I used this fix on our '02 coupe. I used Tridon flasher EL-12, got it at autozone.
Simple, remove knee panel, follow the link, replace panel, done!
Old 09-05-2011, 08:02 AM
JW Motorsports
Banned Scam/Spammer
Originally Posted by JW@JWMotoring.com
This will fix it
100% plug n play. Not sure I would want to hack my wires up.
Yes it will fix your issue. You do not need leds installed for it to work.
Old 09-05-2011, 08:44 AM
shadowman1
shadowman1's Avatar
[QUOTE=JW@JWMotoring.com;1578611230]100% plug n play. Not sure I would want to hack my wires up.
This simply involves cutting 2 wires under the dash and installing 2 female spade terminals to plug into a new flasher.
I didn't see any step which called for "hack the wires" in the instructions. Maybe you can point that step out.
Must have missed that.
Dave
Old 09-05-2011, 08:59 AM
JW Motorsports
Banned Scam/Spammer
[quote=shadowman1;1578611433]
Dave
Highlighted in bold.
No cutting with our harness.
Old 09-05-2011, 10:28 AM
0Tampa Tuning
Former Vendor
St. Jude Donor '12
I installed the below harness before my tail lights and it work. Then I said what the heck, I might as well get the tail lights lol.
This will fix it
Thats the one I bought. Im 6'2" 240 lbs and taking apart the dash to get to the hazard flasher, or splicing wires under the steering wheel, didnt sound fun while upside down
15 minutes plug in the harness and drive.
Old 09-05-2011, 10:58 AM
shadowman1
shadowman1's Avatar
www.merriam-webster.com/dictionary/hack -
a. to cut or sever with repeated irregular or unskillful blows b : to cut or shape by or as if by crude or ruthless strokes
Old 09-05-2011, 11:11 AM
Jazzster
Jazzster's Avatar
Is this turning into an antisymantic thread?
jazz
Old 09-05-2011, 08:38 PM
dklowrider
dklowrider's Avatar
c. to introduce thoughts not directly related to the context of the original question. as in:to hack a thread.
Old 09-05-2011, 09:32 PM
Rebel 1
Rebel 1's Avatar
There is no "hacking of wires" in the Link Shadowman1 posted.
I and others have used this very same fix, it's quick, clean and will Permanently fix the signal problem.
Cost? $9.00 for the high quality Tridon flasher.
Edit: You connect it by sitting on the seat not "upside down under the steering wheel".
Bob
Old 09-06-2011, 09:06 AM
Sinister-one
Sinister-one's Avatar
Phil
www.TampaTuning.com
This will fix it
If you want to spend $60.00 and 15 minutes of your time go this route.
Dave
If you want to spend $9.00 - $10.00 and 15 minutes of your time go this route.
Either way, it fixes the problem.
Old 09-11-2011, 05:25 PM
rtriker
rtriker's Avatar
Thanks everyone for your suggestions about my turnsignal problem you have all been very helpful I greatly appreciate it!!! Russ
Old 09-15-2011, 02:35 AM
scottyz06
3rd Gear
scottyz06's Avatar
THX for the tips ... My 2000 C5 does the same blinker deal .. but when it was acting up ,some told me my rt brake lites were out ? Still the same problem ?? Mahalo , Scotty
To Turn Signals
Quick Reply: Turn Signals
